Results 1 to 10 of 11
Thread: Saw this cheap 15k RGB monitor on Ebay.. Not mine.
    Feb 2009
    Chattanooga, TN - USA
    872
    Default Saw this cheap 15k RGB monitor on Ebay.. Not mine.
    I was browsing old tvs and saw this.
    https://www.ebay.com/itm/1984-Videot...0AAOSwVqlaA1Bm
    Looks to me to be a composite / rgb monitor (15k). (Or not RGB, see the post by next further down the thread)
    Can't remember the name of the connector, but I used on like this in the 80's for my c128's rgb output.
    He's asking $31.66 + shipping.
    Oct 2017
    SE Michigan, USA
    557
    That's not a bad price. It's a digital RGB connector, according to this site.
    5,897
    44
    I know of that plug existing before digital RGB was a thing for that connector. You will want to verify that the TV supports it before buying.
    http://www.labguysworld.com/8PinVTR.gif
    Quote Originally Posted by LabGuysWorld
    Old EIAJ VTR decks and monitors had this convenient connector. It saved the operator from having to connect four separate cable in order to record off air programs. The jumper cable contains four high quality coax cables within it. This cable was wired one to one, straight through as shown above. On the monitor end, simply reverse the in/out nomenclatures.
    If you make up your own cables or adapters, be sure to connect the grounds precisely as shown. Also do not tie the grounds together. You may introduce ground loops or cross talk problems that you really don't need.
    Video levels are, once again, standard 1Vp-p, sync negative, terminated into 75 ohms. Audio input level is -20 dB, high impedance. Audio output level is 0 dB, high impedance. This information comes from the Sony CV-2600 service manual.
    - http://www.labguysworld.com/Connectors.htm
    Dec 2016
    New Jersey
    268
    This connector was used on the Tandy 2000 high res RGB monitor as well as a host of Sony computers. They usually supported greater than 15khz, going all the way to 640*400.
    Feb 2009
    872
    Well, learning new things every day. I'm going to go with Next's post. So maybe not a RGB monitor.
    I had one of these...
    https://www.ebay.com/itm/Vtg-1980s-S...AAAOSwnTdaDmNu
    Back in the day with my 128, so I assumed that having that connector it was rgb.
    33,446
    If you end up with the monitor, I believe I have a plug for the 8-pin connection somewhere in my hellbox. It was originally part of a cable for a Japanese monitor back in the early 80s. The nameplate on the thing said "100VAC" for the line voltage, per Japanese convention, but it worked well on 120VAC.
    Aug 2013
    Philadelphia,PA area
    115
    This monitor is a Sony broadcast video monitor. It isn't a television set, it doesn't appear to have a tuner. The connector is to connect a VTR/VCR up to it. Videotek is a company from Pottstown PA that made commercial video broadcast/surveillance equipment not computer equipment. It has composite video/audio In & loopthrough connectors.
    HTH,
    Tom
    Sep 2003
    Ohio/USA
    7,838
    The top does look like it has a spot for an antenna.
    Oct 2009
    Huntsville, AL
    1,256
    It's funny if you look at the back it shows Sony KV-1365 as the model number above the Videotek sticker... but the front controls and the back panel don't match the manual I found.
    5,897
    44
    Quote Originally Posted by geoffm3 View Post
    The model may refer to the chassis and not the body.
    Thank like how the Commodore 1702 does not share the same controls or chassis but shares a nearly identical enclosure to the JVC television set it was based from (and still has the indent for the removable antenna) or how one model of the video display for the TRS-80 Model I was by all means an RCA television with the RF stage removed.
