Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
Thread: Sometimes I love exploding capacitors
  1. #31
    Capacitor? You'll call that a capacitor? This is a capacitor:
    That's a 4uF 40 kV test frankencap one of several I have for tesla coil experiments.
  2. #32
    Jan 2014
    Melbourne, Australia
    550
    I wouldn't want to be around that if it went off.
    Bobby.
  3. #33
    Apr 2015
    Austin, Texas
    1,305
    I had a trial by fire recapping my first Asus board (P4P800-E Deluxe).
    It showed me that Asus prints component maskings backwards on all components, so when I powered the board up after recapping nearly the entire board, every cap erupted in my face and sprayed electrolyte everywhere. When re-capping it a second time, I had to constantly remind myself to install all of the caps backwards. The only three manufacturers I've ever seen do it are Asus, ASRock and Pegatron (which are all the same company now.)
    I've had a few close calls with caps detonating inside PSUs, fortunately the case contained the shrapnel.
  4. #34
    Dec 2005
    Toronto ON Canada
    7,044
    FWIW, I always draw a map showing values and orientation before removing old caps for replacement.
  5. #35
    Jan 2014
    Centero
    6,525
    2
    So do I, but I've had capacitors in recent years that exploded, or at least became an open circuit, on first power-up, even when installed correctly. I don't know if the capacitors are mislabeled or just really poor quality.
    A scrap sheet of perspex goes a long way.
