Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Olivetti M300-05 battery dead and hard drive not recognized
    Oct 2014
    near frankfurt/m, germany
    745
    No, there is nothing specific to do, the M300 is technically not a special system which needs special setup. Which DOS version do you use?
    Apr 2017
    Belgium, West Flanders
    39
    Quote Originally Posted by 1ST1 View Post
    Hi, I'm using DOS 6.22
    I got it working after doing following:
    - set bios to correct hard drive type
    - delete hdd partition with delpart.exe (I don't think this step is needed)
    - use FDISK to create partition of maximum size 41MB (it's a 54MB hdd, but bios type 36 is a 40MB hdd setting. It's the original hdd, so the size difference is normal).
    - format C with command: FORMAT C: /S
    Now the PC boots to the hard drive!
    After that I installed DOS 6.22 and it wouldn't start anymore.
    When I checked with FDISK the partition got a size of 50MB instead of 40MB. I didn't use FDISK to recreate a partition of 50MB and DOS setup did not format the disk (but it did rename it).
    So in the end I did the first steps again, ending with "FORMAT C: /S" and then just copied some DOS files manually to the hard drive.
    I tried Wolfenstein 3D, it's working fine.
    don't forget that your system has a configuration error, this message should desappear when you get back to setup defaults.
