Results 1 to 5 of 5
Thread: Aptiva 2176 processor upgrade
    Sep 2016
    Shrewsbury, MA
    570
    Default Aptiva 2176 processor upgrade
    Just picked up my second Aptiva 2176, with a factory Pentium 133. I swapped in a Pentium 200, that I know both works and is compatible, but nothing is showing up on the screen. I'm assuming I need to swap some jumpers around, and I found the following website with the jumper info, but can someone explain the clock speed and multiplier settings to me?
    https://stason.org/TULARC/pc/motherb...-2176-A-1.html
    Apr 2015
    Austin, Texas
    1,305
    Stupid definition of multipliers is stupid on that motherboard.
    Install jumpers across J35 from pins 1-2 and 3-4. DO NOT install them in any other orientation or motherboard destruction may result. If you're unsure, don't bother until you know enough about setting jumpers.
    Also set JP10 to position 2-3 and JP11 to 1-2.
    Before moving jumpers around, write down or take a picture of their original positions in case you have to go back. If you do not have enough jumpers, steal some off of old IDE hard drives or CD-ROMs.
    Sep 2016
    Shrewsbury, MA
    570
    I figured it was a stupid IBM design. I haven't done anything yet, but upon closer inspection, I have a different motherboard than the one listed and I can't find a manual. Guess I'm sticking with 166 mhz for the time being.
    Apr 2015
    Austin, Texas
    1,305
    I saw a few motherboards when I looked up "Aptiva 2176", the one on the Stason page wasn't among them. You might have a different sub-model with a different board.
    A picture of your board would be helpful in identifying which one it actually is.
  5. Default
    I happen to have a 200mhz Aptiva. Maybe its the same board? Send a pic and i can compare it.
    Tandy 1000EX/SX/HX/TL3/RLHD, Tandy 2500SX-MultiMedia/SX-33, Coco 1, Coco 3, TRS-80 4p
    Looking for a 1000TX mobo, EX/HX Serial / Parallel cards, and that little tab from the upper right corner of a Tandy keyboard that holds the function key labels in place
