Results 1 to 7 of 7
Thread: Tandy 1000T / S:L - Memory Expansion past 768K and CD-ROM
    Pittsburgh, PA
    1,199
    Default Tandy 1000T / S:L - Memory Expansion past 768K and CD-ROM
    Will the Tandy 1000TL or SL support installing ISA Memory Expansion boards that have 1 or 2 MB of RAM on them or would they not work at all?
    Also, is there any benefit to installing a SCSI or IDE CD-ROM Drive in an SL or TL?
    "In Life, The Days Are Long But The Years Are Short..."
    Expanded memory requires a driver
  3. Default
    I can’t think of any reason to use a CD on something that old. I have a Backpack CD that I use for older machines, and never ever had the need to connect it to a Tandy 1000. I just do the old 3.5 and 5.25 floppies and a parralel Zip drive. All that, along with a removable CF hard drive is way more than enough to backup and move data around.
    If you really want to do an internal CD, a Soundblaster might be an easy way to hook one up too.
    Tandy 1000EX/SX/HX/TL3/RLHD, Tandy 2500SX-MultiMedia/SX-33, Coco 1, Coco 3, TRS-80 4p
    Looking for a 1000TX mobo, EX/HX Serial / Parallel cards, and that little tab from the upper right corner of a Tandy keyboard that holds the function key labels in place
    Pittsburgh, PA
    1,199
    Quote Originally Posted by rmay635703 View Post
    Is it a specific Tandy Driver or a specific driver for each individual Memory expansion card?
    3,960
    Quote Originally Posted by Smack2k View Post
    Specific driver per card though some companies made drivers that handled the whole product line and some drivers could work with cards from multiple manufacturers.
    5,477
    There is little benefit to doing either of these because the class of software that can utilize those doesn't run on that class of hardware. Are you trying to run software that requires a CDROM or Expanded memory?
    I've been wondering myself if there's any kind of hardware mod that can be performed to bring the memory up to 768K on a Tandy 1000 SL. It kind of sucks to have to reserve 64K for video from your 640K conventional.
    Expanded memory in a SL in my opinion is really not necessary, even on my 16MHz V30 Frankenstein.
