Results 1 to 4 of 4
Thread: Using vintage HD bezel w/modern drive. HACK
    Nov 2008
    Portsmouth RI
    361
    Default Using vintage HD bezel w/modern drive. HACK
    1st this is a hack job.
    2nd it's really simple.
    3rd I know I misspelled bezel in the photos
    To keep the vintage look when installing a modernish HD into an old 5150 or 5160 use the original HD bezzel.
    The photos below show my solution.
    Hope that helps someone.
    This is currently not installed as I got another MFM drive for the system.
    framer
    29,610
    20
    It looks as if you've gone a bit overboard. If this were my machine, I'd just use a stock 5.25-to-3.5 adapter bracket and then velcro the FH faceplate to the front of the unit, adding a wood block if necessary to hold the velcro strips. Shouldn't take more than 15 mintues.
    (FWIW, there were several makes of FH HDs that used vecro-type fasteners for their faceplates. So completely contemporaneous)
    I did similar to my XT 286 a long time back, I removed the knackered ST225 from the frame and secured a flat plate on top of the frame, Secured a CF adapter to the plate using plastic standoffs with the sticky tape on the bottom and wired the LED up on the original front panel, Works a treat and keeps it sorta original looking.
    Jan 2014
    Melbourne, Australia
    550
    I just glued the front panel to a plastic 5.25-3.5 adapter...
    Bobby.
