Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: H11 (LSI-11) Troubleshooting
    Ok, more work today:
    o I replaced the three chips relating to the BEVNT signal (two quad opamps and a multivibrator) and the clock signal is now stable but only about 42Hz, not 60. The 7270 is set to ignore the signal anyway.
    o System still exhibits the same random-character problem.
    I'm hoping to get a spare M8043 (DLV11J) and M7270 from a friend of mine to aid in the troubleshooting. At this point I feel that swapping the boards is the only way to narrow it down.
    Ok, here's an update. I received "test" boards to swap in-and-out of my system and it seems that two things happened to my system when the 12v rail failed a few months ago. Thankfully, the CPU card is fine, but it compromised BOTH SLU cards and the RUN toggle no longer works. So, I will replace the 1488/1489 drivers and UAR/T on both boards and see if that makes a difference. Fixing the RUN should also be somewhat easy since it's only the flip-flop to replace.
    Good projects for a rainy N'oreaster day.
    EDIT: Looks like I might have solved the RUN issue. Still a few other things to iron out. The two old SLUs exhibit the same garbage character issues even after replacing the UAR/T and drivers. Putting them aside for now.
    Quote Originally Posted by RichCini View Post
    The receiver / transmitter chips are not 1488/1489 but DS9636/9638/9639 8 pin DIL chips on the DLV11-J. I have quite many of these failing on my DLV11-J. Don't really know why. I almost never have problem with the 1488/1489 on other boards.
    My fault, I should have been clearer in my description. The Heathkit SLUs use a 6402 UAR/T and a 1488/1489 combo. The test card I'm using is the DLV11-J, which works perfectly.
