Results 1 to 2 of 2
Thread: Setting up windows 1.04 system with printer
    Default Setting up windows 1.04 system with printer
    Hi
    Id'l like to set up a PC running windows 1.04. I'm going to copy mouse driver file from windows 2.03 in order to get PS/2 mouse working properly. In top of that, I want to add a printer to my setup. I have Star NX-1000 printer but I have no idea, will it work with windows 1.04? If not, do You know any other printers with availible drivers that I could use?
    Mike
    Does anyone know anything about using Okidata 321 printer as Epson FX / IBM Graphics / IBM Proprinter?
    5,599
    This manual https://www.star-m.jp/eng/service/us...l/nx1000um.pdf should help. It claims it is Epson and IBM compatible.
