Results 1 to 3 of 3
Thread: Dilog DQ419 Floppy Controller with Shugart 860 Floppy Drive on LSI-11/23+ system
    Default Dilog DQ419 Floppy Controller with Shugart 860 Floppy Drive on LSI-11/23+ system
    Using a 3M SS,SD diskette I did a low level format under ODT. Then running a TU58EM emulation of RT11v4 I did a format and an initialization. I got illegal directory messages after each step. Next wanting to see if I could read a diskette I obtained a 3 diskette set of an RT-11 V4.0 Autopch. I am able to read the directories and type out a couple of .com files. I then attempted formatting and initialization on these but retained the files (protected) on the diskettes. I tried copying a file from DD0: to DY0: and once again the drive seems to be going through the operation but the copy does not take place. So it seems I can read diskettes but not write to them. So is the problem with the floppy controller or the floppy drive? All help appreciated.
    Thank you very much.
    Al
    Sep 2006
    Silicon Valley
    1,732
    Quote Originally Posted by lsi11al View Post
    Obvious question, did you put the write-enable tab on the disks?
    8" floppies have the opposite sense for the write-protect tabs
    Yes I did!
