Thread: Old new 386 motherboard
    Sep 2008
    SE MI
    4,344
    6
    Default Old new 386 motherboard
    I bought a Peak/DM 386 motherboard the other day with the understanding that it was removed from a Token Ring server. The seller says he is unable to get the mobo to boot because he thinks the ability to boot was through an ISA Token Ring card, which contain the necessary data. Looks like this may very well be my winter project.
    I would dearly appreciate info from anyone having some knowledge on this sort of setup. The board in on its way and should be here before the end of the week.
    As always, thanks in advance.
    Tom
    I may have a few token ring parts for you. I inherited some hubs and stuff a few years ago and as you know, I don't thrown things out. (well, unless under extreme duress)
    I've got a token ring cable if you need it.
    Sep 2008
    SE MI
    4,344
    6
    Ole & Stone
    Thanks for the offer. What I don't want to do is get involved with a Token Ring lash-up. I need to figure out how to modify the Peak BIOS so it boots without a TR card. I have a spare 386/40 AMI BIOS chip that I plan on slipping into the PEAK mobo, just to see if it will boot. If it does boot, then I'm going to need some help on getting the BIOS routines straightened out. Seems like this one is going to be a challenge. I don't have the where-with-all to edit and/or flash a BIOS chip. I should have hands on later this week.
    P.S. When you look at a photo of the board, it's basically no different than any other 386/33 that you've ever seen.
    Ole/Stone: Have you ever seen a TR setup that required an ISA card just to boot?
    I'm not familiar with Token Ring.
    I just have an 8' NIB IBM Token Ring Network PC Adapter Cable.
