Results 1 to 3 of 3
Thread: What kind of 'power cord' is on this Tec 4012
    Jan 2011
    Vancouver, BC
    3,376
    Default What kind of 'power cord' is on this Tec 4012
    I'm assuming this has something to do with it being rackmount?
    https://rover.ebay.com/rover/0/0/0?m...2F401576462803
    Jun 2012
    UK - Worcester
    2,006
    I suspect this is a Ringlock connector (https://www.ittcannon.com/products/t...ringlock-(tr)/).
    We use these a lot at work.
    I would suspect that it isn't a power lead - but the signal lead.
    We use these because they are pretty robust. We don't use them on rack mounted equipment (they tend not to be moved that much) - but we use them on mobile equipment with 'gorillas' - so robust is good!
    Sep 2006
    Silicon Valley
    1,566
    sort of
    that is only the display tube. all of the actual display electronics are in the card cage that is missing which contains all of the
    actual terminal, which is normally in the base that the tube sits on
