Results 1 to 2 of 2
Thread: Petscii BBS Builder: framework for building your own Petscii-enabled BBS for Commodor
    Default Petscii BBS Builder: framework for building your own Petscii-enabled BBS for Commodor
    Just released the source on github, in the README file there is a quick start description on how to build your own BBS. In the sources there is a few of more complex samples, they will be clear after reading the simple "Hello, world" style example.
    https://github.com/sblendorio/petscii-bbs
    Knowledge of Java 1.7+ is required
    Sep 2018
    Richmond Virginia
    5
    Looks pretty tight. Nice work !
