Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Exidy Sorcerer CP/M logical device redirection
  1. #21
    OK, testing the ANA command seems to work in a simulator so this will hopefully work.
    nobyte    EQU    2        ;bit 1 is 'data received';
    ; stuff
        IN    0FDH        ;check RS232 status, result is put in A
        MVI    D,nobyte    ;00000010
        ANA    D        ;AND A with the D register
        JZ    LOOP        ;nothing received, bit 2 is clear so AND sets the Z flag
        IN    0FCH        ;get char received
    ; do stuff
        END
    I'll bolt that into the main code tomorrow and see what happens.
    www.binarydinosaurs.co.uk - UK home computer history
    Where RIFA capacitors come to die
    facebook.com/binarydinosaurs
  2. #22
    28,503
    20
    Why bother with D at all? Why not "ANI nobyte"?
  3. #23
    I'm still learning It's surprising how little reference info can be found though a lot of it is clobbered by web server things and people asking questions about port 8080.
    In the end I found an 8080-Z80 converter (which couldn't do jumps for some reason) and changed the send/receive code but my floppy drives failed after I'd transferred the HEX file across to the Sorcerer, I suspect through heat since the whole kit had been on all night. I'll be back on it tonight.
  4. #24
    May 2018
    Melbourne, Australia
    71
    Quote Originally Posted by Witchy View Post
    You know that if you prepend a minus character in the front of the search term you're not interested in you can eliminate pages containing that term from the search results ie '8080 assembler -port'.
  5. #25
    Oh yes. It's always a good feeling when you minus out a load of search terms for CP/M stuff and it comes back with 'no results found'
