Results 1 to 3 of 3
Thread: Who made SWTPC chassis?
    Jan 2011
    Vancouver, BC
    3,376
    Default Who made SWTPC chassis?
    A little side project I have going with my collection is to try and match setups in certain catalogs/brochures from companies like SWTPC.
    One of those is to collect everything that appears here on this SWTPC brochure photo:
    After a long hunt, I just scored this Motorola 9" TV - the same one used in all of their advertising for the 6800/CT1024/GT-6144.
    I'm not going to get it exact - my CT-1024 has a different case/chassis, and getting a 6800 with the silver trim around the front would be very difficult (and expensive). But I'm pretty close. I even have the same tape decks. The only piece I'm missing is the PR-40 printer, which will be tricky because unfortunately it is prized by Apple 1 people, who are far more numerous and rabid than SWTPC people.
    Anyway, I'd really like to get a metal chassis made for my GT-6144 that resembles the one in the photo (the GT-6144 is in the center back of the advertisement). This'll make it easier to mount the PSU. I'm wondering if anyone knows who made these for SWTPC/others back in the day (SWTPC, according to the brochure, did not sell or produce them). And if there are any recommendations on where I might go to have one made without getting into $$$$$ ? It's basically just a flat pan bent up at 90 degrees at the back, couple holes drilled. It does have a little flange/edge all the way around so it's kind of like a baking tray.
    Feb 2011
    NorthWest England (East Pondia)
    1,913
    10
    any small engineering firm should be able to make you a chassis, probably cheaply as well. Do you still have wellow pages to look in...
    .. other than that try a model engineering firm.
    G4UGM
    Looking for Analog Computers, Drum Plotters, and Graphics Terminals
    Jan 2013
    Rochester, MN
    4
    What do you consider 'expensive' for a 6800 case with the silver trim?
