Results 1 to 10 of 10
Thread: PC-XT Clone, CGA Monitor - Help troubleshooting
    Dec 2012
    Westchester County, NY
    8
    Default PC-XT Clone, CGA Monitor - Help troubleshooting
    I am trying to bring up a "Premier 200" PC-XT clone, and a Priemier CGA monitor after a 6-year hibernation. The system seems to boot, but the display is garbled. It responds to keyboard activity. Not sure if this is a computer problem or a monitor problem.
    Are there any members in the Ossining NY area that have a CGA monitor and would be willing to help me test?
    Any other suggestion/help with isolating the problem is highly appreciated.
    Thanks,
    Sankar
    It's not likely to be the monitor.
    Try reseating the video card.
    If you're looking for DS/DD or DS/HD 3½" or 5¼" floppy disks, PM me. I've got some new, used, and factory over-labeled disks for sale.
    Dec 2012
    8
    Thanks Stone.
    Unfortunately, the "Video Card" is part of the motherboard ...
    Thanks,
    Sankar
    May 2007
    Oviedo Florida
    1,560
    Perhaps a picture of what you mean by "garbled".
    IBM PS/2 Model 25, NEC V30 8MHz, 640KB RAM, ATI VGA Wonder XL, 2GB SSD, Ethernet, DR DOS 6/GeOS, Xircom PE3 Ethernet
    This may sound strange but... are you sure that's the same monitor the system came with originally?
    Dec 2012
    8
    @evildragon: Wil try to post a picture later today when I get home.
    @Stone: Yes, I have always used them together. They are part of a set - in original packing and boxes.
    Thanks,
    Sankar
    Dec 2012
    8
    @evildragon: Sorry for the delay - attached is the screenshot
    Thanks for your help,
    Sankar
    Dec 2012
    8
    Looks like my post with the screenshot didn't make it - not sure why
    I will again
  9. #9
    Oct 2018
    Sydney, Australia
    6
    Doesn’t look like a monitor problem to me, more like a CGA RAM problem. If the memory is socketed, I’d be inclined to remove and then re-insert to see if that makes a difference.
  10. #10
    Aug 2006
    Chicagoland, Illinois, USA
    5,405
    Screenshot made it through. Based on the photo, your monitor is fine, but you have RAM errors, likely on the video card's RAM.
    Offering a bounty for:
