Results 1 to 10 of 13
Thread: Acquired a IIGS..but it won't boot to GS/OS?
    Nov 2016
    Quakertown, Pennsylvania
    250
    Default Acquired a IIGS..but it won't boot to GS/OS?
    I just recently acquired a complete IIGS system (well, with a Mac keyboard/mouse and an Applied Engineering 5.25 floppy drive) and I managed to make a GS/OS disk and a game disk for testing but I just cannot actually get the system to boot into GS/OS. Trying to boot off the GS/OS crashes every single time with an 0308 fatal error (the explanation of which I found makes zero sense to me) and the game disk (which seems to be a booter) tries to boot but instead gets kicked to the monitor instead. Are my disks somehow bad or could the problem be with the IIGS itself?
    I'm trying to boot GS/OS 5.0.4, which should run given I have a fully populated 1MB RAM card.
    try the self diagnostic, hold open-apple and option keys then power on. it should flash colors for awhile then System Good
    Larry G
    Quote Originally Posted by itsvince725 View Post
    I'm going to assume the machine is a ROM 01 or ROM 3. If you machine just says "Apple IIgs" at boot, it needs a ROM upgrade to run GS/OS.
    Crashing to monitor is rather common with bad memory or a corrupt floppy, although the latter you can usually hear as the external 3.5" drive will make obvious re-seek noises. Run the built in self test, see if it passes. For testing the RAM card, this test is handy and doesn't require GS/OS: http://mmt.gwlink.net/
    Nov 2016
    250
    It passes the self-test with a System Good mention just fine, and it's a ROM 01. Forgot to mention that part. Yeah, when it goes to monitor the floppy stops seeking altogether, I'll have to try that test out.
    Sep 2003
    Ohio/USA
    7,004
    I have yet to figure out how to make a usable bootable disk from a *.shk file without a GS/OS running IIgs. Odd nobody made a utility to do this on a 68k mac (or have I just never run into one?). There are utilities to do this on a PC (read the SHK files).
    Apple 1Mb RAM cards came with 256K soldered on board and 3 more banks of socketed RAM chips. If the card has bad ram it is repairable once you narrow down which chip it is.
    try holding shift on boot to avoid loading extra "stuff". See this:
    https://groups.google.com/forum/#!searchin/comp.sys.apple2/system$20error$200308%7Csort:date/comp.sys.apple2/f1INiv7f_a8/WV38-6HEBwAJ
    solution was to reload gsos
    Larry G
    Nov 2016
    250
    Shift-booting doesn't work, instead of crashing while trying to load GS/OS the system just freezes about 7/8 into the progress bar.
    wait a minute, do you only have a 5.25 drive? I don't think there is enough disk space to hold the full System 5.0.4 required to reach the Finder
  9. Default
    Quote Originally Posted by retrogear View Post
    Definitely not. The Finder barely fits on a minimal 800K disk with the rest of the system files.
    Nov 2016
    250
    Oh no, I have one of each drive.
