+ Reply to Thread
Results 1 to 7 of 7
Thread: n00b issue? Replies to a thread I started not appearing.
    Default n00b issue? Replies to a thread I started not appearing.
    Hi,
    I started this thread a little while ago:
    http://www.vcfed.org/forum/showthrea...-Manual-Needed
    Several people have replied. I've tried replying in the thread twice now and neither has appeared. The first try was two days ago and then yesterday.
    I was using this account (GeoffC).
    Can someone explain what I might be doing wrong if anything?
    Thanks.
    Geoff
    Mar 2011
    Norway/Japan
    924
    I see three posts from you in that thread. The first post, and two replies (with about half a day between)
    Jan 2014
    Freedom City
    6,372
    2
    Until you have ten posts, all your posts will be severely delayed.
    Mar 2009
    Pleasant Hill, CA USA
    2,637
    Until you have ten posts, all your posts will be reviewed by mods.
    Fixed that for you.
    The mods review *every* post by new people that have under 10 posts, and about 33% of them are usually SPAM. And there are a limited number of mods, and new posts sometimes slip through the cracks, we're only human after all.
    +1 on the fixing.
    Thanks everyone - after a day or two I was starting to wonder.
    I see the posts have appeared and will try to exercise more patience.
    Geoff
    Jan 2014
    Freedom City
    6,372
    2
    My only error was to write "will" in stead of "may".
+ Reply to Thread
Tags for this Thread
  • You may post new threads
  • You may post replies
  • You may edit your posts
