Results 1 to 6 of 6
Thread: Planet ENW-2400P-T NE2000 clone DOS driver / utility
    Cool Planet ENW-2400P-T NE2000 clone DOS driver / utility
    Does anyone know where I can find the Planet ENW-2400P-T NE2000 clone DOS driver / utility? 16BIT NE2000 ISA PCB.
    Found this JP site but the DOS utility does not work. Tried the jumper settings to set to PNP to no avail.
    https://www.planex.co.jp/support/dow...t/driver.shtml
    Did you try the setup utility?
    Yes. It throws back an error saying it cannot find the card.
    A 3C509 in the same ISA slot is found just fine.
    The card might be hosed or improperly jumpered for the setup program. JP1/H should be set to open for PNP mode.
    Just use the 3C509.
    Jumper was open.
    Maybe it is garbage. Will try it with Windows 98 SE at some point.
    Cool
    It turns out it works great. After I pealed the Netware Yes! sticker off the main chip I downloaded the Realtek utility. It is equipped with a Realtek RTL8019AS controller chip. Works great with a generic NE2000 driver stack.
    http://www.realtek.com.tw/downloads/...Downloads=true
