Results 1 to 3 of 3
Thread: USB mouse to ADB or non-ADB NeXT
    Feb 2018
    Bucks County, Eastern PA
    85
    Default USB mouse to ADB or non-ADB NeXT
    I'd like to use a modern mouse on my NeXTstation color, but the ball & roller mouse is extremely unpleasant to use, has a bad acceleration curve and needs to be cleaned constantly (possibly the plastic of the ball is no longer grippy enough?).
    Anyhow I'd like to use a modern mouse with configurable DPI and no moving parts. Is there a USB to ADB or NeXT Non-ADB peripherals connector available? I googled in some and found only incomplete or abandoned projects.
    Thanks!
    🕹💾 collecting Commodore, Apple, Next, IBM & making them shiny again 📺✨
    https://www.bigmessowires.com/usb-wombat/
    Compatibility
    The Wombat hardware is compatible with all Apple computers, keyboards, and mice using a mini DIN 4-pin ADB connector, including most early Macintosh computers, the Apple IIgs, and some NeXT computer models. It is also compatible with standard USB keyboards and mice with a USB-A connector. When in ADB-to-USB conversion mode, it works under Windows, OSX, Linux, Chrome OS, or any other operating system that supports USB HID input peripherals.
