Results 1 to 4 of 4
Thread: Orchid Prodesigner/e
    Default Orchid Prodesigner/e
    I recently got an Orchid Prodesigner/e VGA (and EGA?) video card to go in one of my 386 machines. I've spent the past week looking for a manual and jumper settings on this card. Looking for help. In addition to this card I have a Prodesigner/II and there is a lot of information available for nearly any version of that card (with the exception of the translation bios, which I could use a copy of the rom file). Both of my Orchid cards are the 16-bit ISA versions. The attached image is the card I need a manual for.
    Oct 2018
    Chattanooga, TN, USA
    8
    Thar is basically an ET3000 card. The DIP switch might be specific to Orchid. But I would start looking to find anything about ET3000 cards. I remember that any DOS applications with graphics worked fine when setup for ET3000. Unfortunately I did not scan the manuals when I sold that thing about 20 years ago.
    Markus.
    Quote Originally Posted by Krunkthemadman View Post
    This may be what you're looking for:
    http://www.vcfed.org/forum/showthrea...ranslation-ROM
    Thanks for all the replies. I'll run these down.
