Results 1 to 9 of 9
Thread: ISA NIC card blues
    May 2016
    Fairfield, Ohio
    355
    Default ISA NIC card blues
    While digging through one of my spares boxes for something else, I came across an old IBM BNC network card. That reminded me that my Compaq Plus has a BNC & AUI card in it.
    The IBM looks almost exactly like this one:
    https://www.ebay.com/itm/IBM-56X4927...-/111748760111
    I can't say for the other, since I haven't cracked that Plus open in a while. Now that I think about it, I don't believe I've fired it up recently either.
    Anyway. I was wondering if there were some fairly inexpensive way adapt those cards to a modern Ethernet network. Is there something like a BNC to RJ, or AUI to RJ adapter out there?
    May 2009
    Connecticut
    4,129
    The card on Ebay is a 3270 emulator card and only useful if you have a mainframe to hook into. http://ps-2.kev009.com/eprmhtml/eprm0/f2093.htm Most likely you do not want a card like that.
    Probably do not want IBM cards at all since much of their network cards were for Token Ring and thus not easily integrated into a Ethernet network.
    Adapters to take BNC into RJ 45 do exist; quick check shows some cost about $20. I don't remember good results from them.
    May 2016
    Fairfield, Ohio
    355
    Thank you. I was wondering about that card, but all the references I could find referred to an "IBM coax ethernet card." Ditto for the Token Ring. I knew about that, but figured all those references can't be wrong...
    EDIT: I wonder if it came from the same machine that had my IBM 5250 Emulator card in it. I got some of this stuff so long ago I've forgotten the origins. A pity I didn't take notes at the time.
    Cool
    There are hubs/switches that bridge UTP and coax. That is an option as well.
    May 2016
    Fairfield, Ohio
    355
    I've done some looking around, and it seems like the more economic stuff is designed for audio/video as opposed to Ethernet. The prices range from ~$20 to $90 to over $150. The lower prices seem to work for A/V, and the transceivers (utp to either BNC or AUI) that look like they should do the job are upwards of $50 or more. At those prices it would be cheaper to find an 8-bit ISA 10baseT card.
    I've tried googling "utp to coax" & "utp to aui." Can anyone suggest a better search string? This is a low-priority, shoestring project. Don't have much funds for it.
    You can browse ethernet hubs and those with BNC will pop up.
    One example: http://cgi.ebay.com/372442794137
    Another: http://cgi.ebay.com/173553434438
    You will need a coax cable, T-pieces and two 50OHM terminators as well obviously.
    You may find this stuff cheaper on Craigslist / Facebook Marketplace / OfferUp / LetGo locally.
    A few years ago I tried NetWare wih a 8086 with 640KB RAM. With a NE1000 and BNC. Turned out a parallel LapLink cable and INTERSVR AND INTERLNK worked a lot better for remote HDD sharing.
    Jan 2014
    Centero
    6,621
    2
    AUI transceivers exist. They yoostaby a dime a dozen. I have a handful of them (all in use).
    I just wanted to mention that in many cases 16-bit cards work in an 8-bit slot. Myself, I have a SMC8000 based 16-bit card in my XT clone.
  9. #9
    Feb 2012
    New Zealand
    2,593
    2
    This ^
    Having AUI connectors is actually a godsend sometimes because you can connect to anything using transceivers.
    Just an example on ebay: https://www.ebay.com/itm/Cisco-2500-...:rk:4:razz:f:0
    But I got all mine for like $1 or free to be honest.
    WTB: IBM RT Parts and Accessories, and AOS.
    Twitter / Discord / YouTube / Twitch
