Results 1 to 4 of 4
Thread: IBM 5364 S/36 PC on eBay (not mine)
    Jun 2018
    Los Angeles, CA
    106
    Default IBM 5364 S/36 PC on eBay (not mine)
    Looks interesting, don't know exactly what it is, but it's probably pretty rare.
    https://www.ebay.com/itm/RARE-IBM-s-...rk:26:razz:f:0
    Nov 2012
    Richmond Hill, Ontario, Canada
    1,003
    This is on my want list and I did see this but the damage makes it a little less desirable. It's too bad that side was damaged or it would be great. Thanks for posting.
    Jun 2018
    Los Angeles, CA
    106
    You could probably salvage the power switch plastic a different power supply and sand/repaint the case if you really wanted to. But, I agree it could be in better condition.
    Oct 2008
    Kamloops, BC, Canada
    5,337
    41
    The 5364 is the model before (though it looks more like after because it's smaller) the 5363 System/36 I briefly owned. It's great in that it's smaller and easily fits on a desk however does not have a local access control panel for doing maintenance or recovering a lost password and needs a large cable and card inside a host IBM system, both of which are missing from this listing.
    Otherwise, it looks like everything is still inside the machine so it might turn on but you will be unable to IPL it.
    = Excellent space heater
