Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 51 to 60 of 82
Thread: M847 extended edition > Bootloader in PDP style !
  1. #51
    Nov 2018
    Galveston, Texas
    15
    Default M847 Extended Edition - Notes on Building
    This note presents my experience in building Roland Huismanís M847 extended edition Bootloader. My intent is to encourage others interested in the board but maybe hesitant based on skill level to take on building the board. I note that the forum topic has more than 5000 views, so I suspect there are more folks like me, who may not be ďexpertĒ builders, but would be interested in having the board if it is not too daunting to build and set upÖ it is a very doable projectÖ
    The board has been great to have installed in my PDP8/E. It allows painless loading of commonly used bootloaders, test programs and setups such as Kyle Owenís SerialDisk program.
    There are lots of ways to build the project, and I certainly donít represent that the way I have gone about it is the best Ė Iím sure others have better ways..
    Important credit goes to Roland Huisman for designing this great add for PDP8 folks. His contribution includes designing the board, writing the Arduino code and clearly and completely presenting the needed info for users (refer to his github site at https://github.com/Roland-Huisman/M8...d-version-V1.1).
    Sourcing of Materials
    I followed Rolandís write-up and ordered the PCB online from JLCPCB.com and used the gerber files on his Github site. Ordering went very smoothly and I got the boards in about 10 days. I did make the mistake of ordering the stencil file. JLCPB got back to me via email the day after I placed the order and helped me understand that I did not need it. Cost for 5 boards was $46, including shipping. (if three folks are being held up by this step, I can send you one of my left over boardsÖ contact me).
    I purchased the individual components from Digikey using Rolandís Bill of Materials in xls format. Use his latest version, as there are a couple of minor updates. I copied the DigiKey part number and quantity columns into a separate spreadsheet and oploaded that directly into the DigiKey order site. I then adjusted for items that I did not need from DigiKey or where I wanted a spare or two. Worked great..
    I ordered the Atmega328-PU from the internet, with bootloader installed Ė thinking that would save a step that I was not familiar with. Long story short, I found that my Arduino Uno does not have native support for the 328-PU. The Uno wants to see a 328P-PU, so I could not download Rolandís code onto the board, nor upload the Arduino bootloader. I know there are ways to get around this, but I recommend (consistent with Rolandís forum post) to purchase the Atmega328P-PU. Digikey has this, and it is included in Rolandís most recent BOM. As I was working to figure the above out, Roland suggested a work-around that got my board running Ė use an Arduino Uno board that has a working 328P and load Rolandís code on to the board then move the Atmega328P chip to the bootloader board. That worked well as I waited for the Atmega328P-PU. With arrival of the Atmega328P-PU, I was able to install it on the bootloader board, burn the Arduino bootloader using Rolandís instructions and a 6-pin IDC cable with his mod (sourced from Adafruit part number 371 at $2.00). I used the Arduino Uno to then download Rolandís code onto the board from my PCís com1 port using a DEC BC01V serial cable from one of my M8655 boards.
    Assembly Notes
    Placement and soldering of the components went well, using the BOM and the pdf file showing placement. An assembly aid that new builders may fine useful is an adjustable circuit board holder (I use an Aven 17010, $12.20 from Amazon with a makeshift extended-length center channel):
    A couple of other tools that new builders may find helpful in assembly Ė a lead bending/forming tool (Jameco 106884 at $4.95) and an IC pin straightener (Jameco 99363 at $7.95):
    Operation
    Once assembled and with the right Atmega328P-PU installed and loaded. I installed the board in my PDP8/E, using an extender board to help with initial testing and familiarization. I use a DEC Compatible Board Extender with 72-125C-EL connectors from Douglas Electronics (part number 6-DE-8-C) for $60.
    On startup of the PDP, Rolandís bootloader board has the AC register show a scan of lights back and forth, then either loads the pre-set program on the boardís DIP switch or awaits either SW keypressing or the small button on the board to load one of the pre-programmed programs.
    I know I speak for many others in saying thanks again to Roland for developing and making this board so readily approachable to the PDP8 community.
    I also know that this write-up is a little sophomoric and unneeded for many of the experienced PDP8 community, but it may help some folks that are on the fence in taking this on to feel more confident that it is readily doable.
  2. #52
    Aug 2010
    Silicon Valley USA
    865
    4
    Quote Originally Posted by mngreer View Post
    This behavior is not my experience. It IS true that putting a blank 328 on an Arduino board will not allow the Arduino tools to download the bootloader, as the tools check the silicon device ID, and it is different between the 328 and 328P. There is a way to fool the Arduino (really avrdude) tool to work around this (using the -F switch to force programming and ignore device ID) but it takes a bit of hacking to do it.
    Once programmed with the bootloader (and correct fuses) the 328 behaves exactly the same as the 328P. The programming model is identical, and Arduino software does not care. So the statement: The Uno wants to see a 328P-PU, so I could not download Rolandís code onto the board, nor upload the Arduino bootloader. is not quite accurate, at least in the first half. The second half re: the bootloader is true, as I indicated previously. But once the bootloader is correctly programmed, Arduino IDE can download software to the 328/328P identically. I have several Arduino 328P boards with DIP devices and I have used both 328 and 328P devices in the same socket, and downloaded Arduino sketches, no problem.
    Other than that nit, it is a very good writeup on building the board and sourcing all the requisite parts.
    If you do insert the board directly into the backplane, I would exercise caution around the DB9 socket as it might inadvertently short against an adjacent board in a slot. I would recommend using some insulating kapton tape over the exposed topside metal edges of the DB9 connector, or gluing some insulating ~1/2" standoffs near the connector to keep it spaced away from the next slot board.
    Don
  3. #53
    I'm glad to hear a success story. I really would love to see more
    I think it helps others to make the step to built it as well...
  4. #54
    Dec 2013
    Near Milwaukee Wisconsin
    1,254
    Well..... another boot loader is in service on a PDP8E. I had followed this thread since the beginning, but was unsure of how to exactly have a board made. I'm studying Ki Cad, but am not to the point where I can do what is needed. Then when Matt G said he had some extra boards, I popped off a message. After the boards were in hand, I purchased the parts to populate the board. I took Roland and Matt's advise and purchased a Arduino with the boot software installed. I purchased two chips for $10 with shipping om eBay. Installing the parts were relatively easy. Next was where I stumbled a little. I didn't know anything about Arduino. I saw Roland's *.ino file, but how does one install it? After a few messages with Roland, watching a bunch of you tube films and reading about Arduino. I found all that is needed is to download the Arduino IDE. The next problem is that my modern computer has a com port, but it is not brought out to a DB9 plug. So I had to purchase a cord for that and a null DB9 cable. Now, I figured I was set to try installing the program. I downloaded Roland's *.ino file from GitHub to my computer. Started up the Arduino IDE and found the ino file and opened it. Next the boot loader board was powered up and connected to my computer via the null cable. From the Arduino IDE program, I clicked the verify button and the upload button. All that took place was a message was displayed at the bottom of the screen that 8202 bytes were transferred. Well, no bad stuff was written so I figured why not try the board. This required going to the cold basement. After bundling up I plugged the board into the PDP8E and the front panel light did the back and for worth pattern and I was optimist that it would work. The PDP8E switch was toggled and the first program (Serial disk Boot) was loaded and OS/8 started up. Hot Dog! I also had taken the time to load up my XRIM.RIM for my REMEX paper tape reader into Roland's program. So, I dialed it up and the REMEX ran as it should. The XLBAA.bin was loaded and after that I could load a MAINDEC file which also worked fine. My XRIM file was added via the IDE program. Programs 16 and 17 were commented out. So I relabeled programs 2-15 as 3-16 and inserted my REMEX boot loader XRIM as program 2
      const PROGMEM word Program_02[] = {0x0200, 0x0000, 0x4220, 0x7106, 0x7006, 0x7510, 0x5200, 0x7006, 0x7040, 0x3232, 0x4220, 0x7040, 0x0232, 0x7040, 0x7420, 0x3633, 0x3233, 0x5200, 0x0000, 0x7240, 0x6506, 0x6502, 0x5223, 0x7240, 0x6503, 0x6505, 0x6504, 0x5620, 0x0200}; // REMEX reader load
    Where 0x0200 is the beginning of the program, 0x0000 is the extended address. The last 0x0200 is the XRIM starting address and the bytes in between are the XRIM code.
    Before my fingers and feet got cold, I also tried program 32, the terminal test and this also worked. I want to try some of the other programs, but will wait until I feel better and it warms a little. This project will enhance my PDP8E immensely. And now that I know a little about the Arduino, I think I may purchase a UNO and experiment with it. Thanks a million Roland, you to Matt for the boards. Mike
  5. #55
    @Mike, very nice to hear your success story! Well done
    For others, I still have this prototype board which I used in the first demo on YouTube.
    It's not as fancy as the newest one because there is no RS232 but only a TTL level
    interface to program the ATMEGA328. So if one has an USB - RS232 TTL converter then you
    can program it as well. Or use an Arduino Uno to program the atmega328 and pull the chip.
    This board is 100% compatible with the current software.
    I've pulled the chips and crystal for the proto's of the current model but it is quite easy
    to make the board complete and working again. In fact, it was already working
    So if anyone likes to have this board just reply here. It's for free, just shipping costs.
    Regards, Roland
    BTW, does anyone know how I can add the Github link to my first post? I can't edit it anymore...
  6. #56
    Aug 2010
    Silicon Valley USA
    865
    4
    Regards, Roland
    Editing a post is now disabled about 15 minutes after you posted it. So you have a very small time window to change/correct/update your posts.
    An alternative would be to create a blog entry. This is like a post, but stands alone, and can be edited by the author any time (even years later).
    Start here: http://www.vcfed.org/forum/blog.php
    Blogs are a little bit harder to find, you have to search for them, but they are more flexible and you can link to them from posts.
    For example, I have these under my userid: Capture.jpg
    Don
  7. #57
    Hi Don, thanks! 15 minutes is quite short to edit.
    As an alternative I've added my GitHub link to my signature.
    And I wonder who is going to get that prototype...
    Regards, Roland
  8. #58
    Yet again, my reply seems to have been deleted.
    I would be interested if still available.
    I left my email address last time; maybe my reply was censored as a result.
    I will try to send a personal message
    Steve G7PSZ
  9. #59
    Yes still available, so it's yours. I will check my PM later...
    Regards, Roland
  10. #60
    Currently I'm working on a firmware update for the M847 Extended edition.
    I will add the kaleidoscope like Vince did and the RX01 address is updated.
    Some other minor updates will come as well...
    The intention of the BIN LOADER is that you can start the bin loader and load BIN files directly.
    But a few times I've seen some strange behaviour according the BIN LOADER program.
    Has anyone used this already? Any experience?
    Can anyone point me to the original BIN LOADER listing with the octal values?
    It seems I haven't used the original from DEC and it seems that it doesn't always work properly.
    And if there are any other suggestions please don't hesitate, just ask...
    Thanks in advance!
    Roland
