Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Gateway 2000 4SX-33 memory?
    My anal retentiveness is telling me to get four sticks of 8MB... thank you for the info! I sincerely appreciate it.
    Roger
    Always interested in Atari 8-bit and 486/early Pentium era software & hardware!
    Aug 2006
    Chicagoland, Illinois, USA
    5,598
    I can't see the part numbers on the memory chips, so I can't tell you if those are FPM or EDO, but I can tell you that those are parity modules.
    I thought EDO RAM was only applicable to the first wave of Pentiums? True or false?
    Offering a bounty for:
    Mostly true, though IIRC, a few of the late Compaq 486s that came across my workbench had EDO...
    Apr 2015
    Austin, Texas
    1,338
    Intel made motherboards with EDO right up until the end of the Pentium MMX. I know because I had several Pentium MMX 200s with four SIMM slots for EDO and no DIMMs.
    Compaq also had a few weird Pentium II workstations which had EDO DIMMs, which were weird 5v 168 pin modules that were a whole lot slower than normal 168 pin SDRAM. A bunch of Apple Powermacs (like the Performa 6360, 6400 and 6500) also used it, which made upgrading their RAM expensive.
  5. #15
    Jan 2014
    Western North Carolina, USA
    1,123
    The first Pentium Pro supermicro motherboard I installed had EDO, and I put 64MB of parity RAM into it, for ECC. 440FX chipset as I recall.
    Sun Ultra 5 and 10 workstations, as well as Cisco 12000-series GRP modules used those 168 pin 5V EDO DIMMS too, up to 512MB per DIMM.
    Last edited by lowen; November 2nd, 2018 at 07:37 AM. Reason: I hate android autoincorrect.....
    Bughlt: Sckmud
    Shut her down Scotty, she's sucking mud again!
  6. #16
    So I got the memory today and installed it... the memory test during start up only shows half of the memory that I installed (32MB shows as 16MB... if I remove two sticks, 16MB shows as 8MB) and I get prompted to go into to setup (F2) and correct the memory size. Once I do that, I still get the error message on start up. It shows 640K in base memory so the extended number is what I'm changing... any suggestions?
    Thank you,
    Roger
  7. #17
    After looking at the memory that I was told I needed, it looks a lot different than what was in the computer. Here's the new memory that I am trying to install:
    Is there anyone that can tell me the "right" type of memory that I need for this computer?!?
    Thank you,
    Roger
