Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: IDE hard drive in XT computer
    I use INTERLNK/SVR and LapLink parallel or serial to connect PCs without HDD to a 486 with a 2GB HDD. This way I have all files centrally. Some software does not work with that solution unfortunately however.
    Jan 2012
    Connecticut, USA
    1,532
    Quote Originally Posted by Krille View Post
    Hey Krille, I traded with RadRacer. I just don't have the time to try getting the XT universal bios working on the Juko card these days.
    Quote Originally Posted by PeterNC View Post
    Peter, there's software that utilizes that same parallel cable setup to run a full client/server network and that aforementioned software will most likely work via that network, enabling the PCs without HDDs to fully utilize the 486's 2GB drive.
    Cool. What software would that be?
  5. #15
    There's Lantastic Z which can use either a serial or a parallel cable and there's U-NET II which is a complete Server/Workstation network via parallel cable.
    Have a look at the manual:
    README.txt
  6. #16
    Interesting. Will have to try those out at some point in the future. Thank you.
