Results 1 to 9 of 9
Thread: Thesys Fastcard IV / PMI / Perhiperal Markeing Inc.
    Default Thesys Fastcard IV / PMI / Perhiperal Markeing Inc.
    I managed to pull the files off the disk. This is "Fast Card IV Utilities 2.0" version. This was right before PMI did the renaming on them.
    I will try and scan the manual over the weekend as well as dump the ROM (v1.06 - 03/25/86)
    https://kråketær.com/fc4_20.zip
    This has the setup utilities, clock, emm driver, etc. Its all here.
    The sad thing, the card is about 2 inches too long to fit in the Tandy 1000 SX
    Sep 2012
    Indiana, USA
    456
    This is great! The final pieces of the puzzle for this card. I was finally able to get it setup properly, and it WORKS! I've had this card several years now, and I didn't even know if it was functional. Let me know if you get around to scanning the manual, and thanks again.
    I do have the manual scanned, by that I mean I did a poor mans scan and take photos with my phone, tied them into a PDF. its about 24mb. I'll see if I can get it on bitsavers or something.
    The setup app is neat, asking you questions then showing you a pictograph of the jumper blocks, its very cool!
    Hello,
    any news about the manual and the ROM dump?
    Am very interested in it. I have a Fastcard III, no I/O, only 2MB of memory board. Hope the drivers you posted will work,ù
    Thanks.
    Vincent.
    I put it on my google drive as a share to all;
    https://drive.google.com/drive/folde...w9?usp=sharing
    I need to check what I did with the ROM(s)
    6,042
    Thank you.
    I also added the user manual and software to [here].
    Thanks, I wasnt quite sure where to put it!
    Hello,
    thank you! I was able to have my Thesys Fastcard III correctly setup. But still it cannot see all the memory. Probably a bad DRAM chip. By a miracle, I also had an hard disk with the Thesys Fastcard III drivers.
    if you can recover the FastCard IV bios dump, I would be pleased to get it.
    Regards, Vincenzo.
    Quote Originally Posted by BloodyCactus View Post
    Attached "v1.06 03/25/86" EPROM. I suspect its an AM27128 but I also read it as an AM27C256 (same pin count).
    There is another rom next to it but it is soldered to the board, not sure I want to desolder and socket it, to dump it yet.
    There is also I believe 9 PAL/GAL's on the board, not sure if trying to dump them would be worth it either, might be fuse locked.
    fc4_rom_106.zip
