Results 1 to 8 of 8
Thread: need help to indetify an 8 bit isa card
    Jun 2013
    Montevideo, Uruguay
    402
    Default need help to indetify an 8 bit isa card
    Hi guys today i found this isa 8 bit card on a flea market and im need help to know what is it and how to use it if possible.
    The card have a text on top that says "PC APPLE TRANSFER CCARD FT-850306 1985 V1.0"
    Fits on a 8bit isa slot and have a 34 pin edge connector and 34 pin connector for floppy drive.
    Searched on google but don't find anything relevant.
    Pictures below.
    32,682
    Looks like a clone of the Micro Solutions Match Point PC. I haven't compared it with mine, but the general layout seems to match.
    4,457
    I suspect it is something similar to the Central Point Copy II PC which would control floppy drives to read Apple II or Mac disks. Plug in the system floppy cable to one of the two floppy connectors, run a cable to the drive being used to read Apple disks and run special software to read the disks. Modifying existing software to work with an unknown card will be a difficult challenge. Try contacting the seller if possible and see if any disks were saved when the system was broken apart. Might get lucky and find the correct disk.
    32,682
    Not at all as sophisticated as the Copy II PC--some SSI TTL and a few PALs.
    I even did one of my own design back in the day. The interesting thing is that the Apple II floppy interface was scarcely more than a ROM, a latch and some buffers as a sequencer--it relied heavily on the 6502 timing. A really detailed explanation of the operation can be found in Jim Sather's "Understanding the Apple II" books. Later, this simple logic was subsumed into the IWM.
    Since there's no cycle-correct emulation of the 6502 possible using the PCs 8088, timings have to be developed through some added circuitry.
    Hi guys today i found this isa 8 bit card on a flea market...
    How would you go about contacting a seller at a flea market?
    4,457
    Go to the next flea market and see if the seller shows up?
    Jun 2013
    Montevideo, Uruguay
    402
    I don't think i will get much more information from the seller in the flea market, when i purchased the boards from him he was in the process of getting stone drunk on cheap wine.
    Hi,
    Did you ever find any software or more info on this card? I wonder if the MatchPoint SW would work with it.
