Results 1 to 10 of 26
Thread: M24-IDE: a 16-bit IDE adapter for the Olivetti M24 / AT&T 6300
    Aug 2017
    New York, Rome, London
    131
    Lightbulb M24-IDE: a 16-bit IDE adapter for the Olivetti M24 / AT&T 6300
    Hello again -
    As I mentioned my newly-acquired AT&T 6300 is missing a hard drive. I have glitchworks's XT-IDE in my Italian Olivetti M24 and it works flawlessly, so I could just get another one. But I've always wondered if it would be possible to remove the latches and have the IDE device communicate with the M24 through a full 16bit-wide data path? After all that's what an 8086 distinguishes itself for!
    So I have spent a bit of time looking at the bus converter schematics (*) and the sequence of signals on the proprietary Olivetti 16-bit bus connector, and I can see no obvious reason why it should not work.
    Olivetti 16-bit data transfers seem to work very similarly to their ISA counterparts, ie an address is presented on the bus, and if the card asserts a specific line (/IOCS16 in ISA, /16BCH in Olivetti) then a 16-bit transfer takes place. There are differences - in the Olivetti case, during a 16-bit transfer cycle the ISA-compatible command lines (/IOR, /IOW, /MEMR, /MEMW) are disabled and alternative Olivetti lines on the 16-bit connector are used (/XIOR, /XIOW, etc).
    With this knowledge, I sketched a possible, simple interface, essentially a simplification of glitch's design split into two boards: a main one that plugs into the ISA-compatible 8-bit slot, and a smaller one that plugs into the Olivetti 16-bit slot. The two would be connected via a short 12-pin ribbon cable.
    I have not breadborded or tested this at all - my ISA breadboard card is old and cranky, and with this many connections user error or breadboard malfunction would be virtually guaranteed. Also, at $5 a pop for professionally-fabricated prototype PCBs I'm willing to just have a board made with a reasonable starting design and then just debug that. (**)
    So my question is... does anyone see any glaring flaws with my schematic, or any obvious reason why the whole thing would not work?
    (*) The bus converter schematics in the Theory of Operation manual does not exactly match mine - probably a different revision. I have a hand-corrected version if anyone is interested.
    (**) I have also not finished routing it yet. It's a lot more complicated than I thought or, most likely, I'm not very good at it.
    (***) Sorry for the zipped version - I know it's not smaller than the .pdf, but the forum won't allow me to upload .pdf's larger than 48kb...
    Attached Files Attached Files
    34,369
    Weren't there a couple of revisions of the 6300/M24 bus converter board?
    Jan 2014
    558
    Interesting! What kind of performance could we expect on something like this?
    Bobby.
    Aug 2017
    131
    I'm sure there must have been - see examples for sale now on eBay with two, three, or four 16-bit slots... !
    Aug 2017
    131
    Quote Originally Posted by bobba84 View Post
    I don't know for sure as I have not timed the 16-bit I/O cycle, but it should be faster than only currently available solution for these PCs (XT-IDE in Compatibility Mode), which uses two separate 8-bit cycles for each IDE 16-bit data access. It should also be faster than an XT-IDE in "Chuck Mod" version if that could be made to work on the M24, since a 16-bit cycle split into two fake 8-bit cycles by the bus converter is slower than a true single 16-bit cycle (I did check this).
    Sep 2017
    Principality of Xeon
    1,861
    Was there a 286(ed) version of these? I know they did a 386, or at least am reasonably sure.
    This is along the lines of a project I had in mind for the Tandy 2000 a long time ago, that is amending and ide card to work with the 80186 based expansion bus. It uses a 96 pin eurocard connector. It's possible much of that which is needed is already there. The NEC APC III (or PC-9801) has C-Bus, and likewise you could at least expect 16 data lines to be present.
    Mar 2011
    Atlanta, GA, USA
    1,593
    Quote Originally Posted by 2icebitn View Post
    Not to hi-jack the thread, but I've looked at doing it for the T2K - and still plan to for Tandy Assembly'19. The T2K - and maybe other work-a-likes - do not have a standard PC BIOS. There is no support for a BIOS option ROM for XT-IDE BIOS. And even if there were, the system ROM in the T2K only has enough of Int 13A to boot-strap DOS from floppy or hard disk and then most of BIOS is replaced from code in IO.SYS - including Int 13A.
    The T2K does use a WD1010/1100 combo on it's hard drive controller - which IDE was based on. And it appears that even though hardware designers added support for DMA and IRQ on sector transfer, the code still only uses PIO and busy-waits. So it may be possible to map an IDE drive's register set in the same spot and things 'just work' - in 8 bit mode. The T2K does use a 80186 - unlike the PC6300's 8086. So the designers heavily leveraged the built-in programmable chip-select lines to make peripheral card decoding easier.
    I'm afraid in order to do a lot more with the T2K, most of the BIOS code needs to be ripped from IO.SYS, combined with the ROM, and updated to a proper PC clone compatible code-base - and placed back in ROM. There is only 16KB of ROM window, but it should be doable - skipping pedantic things like placing handlers at the same segment address as IBM! That's why I disassembled and annotated the T2K ROM and was about half way done with IO.SYS when a squirrel ran by. It would break loading the T2K specific DOS flavors but would allow running of more modern stock DOS versions. I plan on finishing and getting MS-DOS 6.22 booting on it as step 1 toward hard drive emulation.
    -Alan
    Aug 2017
    131
    So I read, but I have not had one personally.
    Yes I have often wondered whether and to what extent these pre-IBM-AT 8086-based PCs had 16-bit expansion cards available for them back in the day. The only such 16-bit cards seen with any regularity on eBay are memory expansion boards for the M24... but maybe I missed others the existence of which I am not aware of.
    In your design, did you make use of the IDE (or ISA) /IOCS16 signal? In my design I critically rely on it working as I expect to select between 8-bit and 16-bit IDE register accesses...
    Aug 2017
    131
    Just a quick update... I finally finished routing it (yep, a year later!). Here is a render of the main board:
    and one of the little board that goes into the 16bit slot:
    I did not put any mounting holes to attach a bracket... mostly because I could not figure out where to place them (suggestions welcome).
    Oct 2014
    near frankfurt/m, germany
    1,054
    Interesting, and it looks so simple. Will it run with the XT-IDE-BIOS?
