Results 1 to 8 of 8
Thread: 5 1/4" Floppy Drive Woes
    Jan 2013
    Pittsburgh, PA
    1,240
    Default 5 1/4" Floppy Drive Woes
    One of my 5 1/4" Drives isnt reading disks...
    When you power on the computer, the system checks both floppy drives (3 1/2 and 5 1/4). The 5 1/4" Drive head moves up and back on the rails during floppy seek.
    Once the system is booted and you insert a disk (1.2 MB Disks in 1.2 MB Drive), the disk spins but the Drive Head does nothing, it just sits there. I cleaned it carefully with cotton swap and some 91% isopropyl but it didnt make a difference...
    Anything I can check / modify on the drive to try and get it working?
    "In Life, The Days Are Long But The Years Are Short..."
    Jan 2013
    Pittsburgh, PA
    1,240
    ITs a Mitsubishi MF504C-318UG
    30,621
    20
    Get a copy of ImageDisk and try some of the tests--see if you can step the carriage in and out.
    30,621
    20
    Oh--and see this thread.
    Jan 2013
    Pittsburgh, PA
    1,240
    Ha, I checked that thread earlier before I posted and everything seems fine and setup right.
    For ImageDisk, does that go on a floppy? My Drive wont read any disks, so not sure how I'd get that to run. Or would I install it on my PC and run the tests>
    30,621
    20
    You need to put it on a hard drive--or at least load it into memory using DEBUG and then execute it. There's really nothing to install--it's just a couple of programs.
    Jan 2013
    Pittsburgh, PA
    1,240
    Sorry for not responding...got the flu....
    Issue ended up being the 8-Bit ISA FLoppy Controller card I had in the system. Pulled it out and put a standard 16-Bit ISA Controller card in and the Floppy Drives worked fine. The issue could also have been that the BIOS had the drives listed for A and B and then the Floppy controller BIOS would run and also list the same A and B...but I didnt notice that until after I had swapped cards....working now though!
    Sep 2008
    SE MI
    3,904
    6
    Quote Originally Posted by Smack2k View Post
    Smack - hope you're feeling better but next year get the shot.
    Surely not everyone was Kung-fu fighting
