Results 1 to 7 of 7
Thread: Juko nest n3
    Dec 2018
    St. Petersburg, Russia
    6
    Default Juko nest n3
    Greetings.
    I need help with this board. It had no CPU (I've installed 12MHz V30) and a strange BIOS, that doesn't look like one for 8086. Both halves are almost identical, and I think that's why this board appears to be dead (no video, no speaker beeps). I've found several photos of this board with v2.01 NEST BIOS, but no luck finding any ROM images for 8086 Juko.
    I've attached my ROM dumps, just in case, in raw and intel hex formats.
    Juko 1_07.zip
    Have you tried a V20 ?
    Those BIOS chips definitely aren't odd/even, so it's likely the bus is 8-bit, just like on those common "Juko Super Turbo" boards.
    Also, it could use some RAM chips...
    33,645
    From the ROM contents, I agree that it's most likely just an 8088/V20 board.
    I did some search, and I'm inclined to believe it really is 8086/V30.
    See this topic - https://www.vogons.org/viewtopic.php?f=46&t=60077
    Edit: also, that famous V'ger XT is based on that board - https://sites.google.com/site/misterzeropage/
    Maybe the owner can provide the correct BIOS?
    33,645
    Worst case--if this uses a "split" BIOS configuration, you could just take a vanilla XT clone BIOS and divide it yourself. That might be enough to get you booted.
    Dec 2018
    6
    This board is definitely 8086/V30 version - I've checked how data lines interconnect on ROM and RAM chips - the data bus is 16 bit.
    I'll try splitting the original BIOS, but I want latest version if possible - working with UV ERPOM is not that easy.
    I know about Anonymous Coward's XT, but I haven't found way to contact him.
    Here are the dumps. Neither the board nor the chips specified which was even or which was odd, so I just named them randomly. If one combination doesn't work, try swapping them around.
    Attached Files Attached Files
    V'Ger XT
