Results 1 to 3 of 3
Thread: Some fun with a microcontroller.
    Nov 2018
    Bennekom, The Netherlands
    13
    Default Some fun with a microcontroller.
    Some useful fun with a microcontroller and old equipment.
    See https://youtu.be/l--OHNxXFeE
    Nice! So Ed = Edward and you have been working with Henk Gooijen on this project?
    WTB: Dec TU56 / Case for Altair 8800
    Nov 2018
    13
    Yes, Henk made the interface board.
    The current software uses a 4 byte command and response protocol and is based on some ideas we had.
    I have done some testing using a small program to do some punching and/or reading.
    As a result of this testing, some minor tweaks to the command protocol could be needed, this will
    then be version 2.
    I am also making a modified pdp11_pt.c (SIMH PC11 emulator module) module which will be a
    a drop-in replacement to allow it to use the real PC05.
