Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
Thread: Chrome/Chromium being too helpful?
  1. #31
    Mar 2009
    Pleasant Hill, CA USA
    2,703
    Hmmmm, I get:
    Server: 127.0.0.53
    Address: 127.0.0.53
    So it's local to my system. Now where is that coming from? Another &*&!@$ systemd "feature"?
    What distro are you running? That would imply your system is running a DNS server of its own, so you are sort of querying localhost for DNS stuff, and the built in DNS server is then forwarding that query to some other DNS server, not an unusual way to do it TBH. Assuming it's Bind, what is the output of "sudo service bind9 status" ?
  2. #32
    Mar 2009
    2,703
    Oh, this might help: https://askubuntu.com/questions/1012...ge-permanently
    Bottom line is it would seem that it is SystemD doing some things, and for some reason they are using your ISPs DNS, which only seems to affect Chromium.
    Here is the suggested way to force the system to use the DNS servers you want:
    sudo apt install resolvconf
    From http://manpages.ubuntu.com/manpages/...olvconf.8.html
    The resolvconf package comprises a simple database for run-time nameserver information and
           a simple framework for notifying applications of changes in that information.   Resolvconf
           thus  sets  itself  up  as  the  intermediary  between  programs  that  supply  nameserver
           information and applications that use that information.
           Information is added to or removed from the database using the  resolvconf  program.   See
           the OPTIONS section below for a discussion of the available options.
    Then implement it this way:
    0. sudo apt install resolvconf
    1. sudo nano /etc/resolvconf/resolv.conf.d/head
    2. Add DNS servers (eg nameserver 8.8.8.8 ), each on their own line.
    3. sudo resolvconf --enable-updates
    4. sudo resolvconf -u
    As I understand it, this will essentially force the system to use the DNS servers you specify in step 2.
  3. #33
    30,621
    20
    Ubuntu 18.04. The 127.0.0.53 is a systemd figment. See this discussion
  4. #34
    Mar 2009
    2,703
    Yeah, I saw that, which is what lead me to read about resolveconf
  5. #35
    30,621
    20
    I was a bit more brute-force than that ("Never use a scalpel when a meataxe will do").
    I created my /etc/resolv.conf and set the immutable attribute.
  6. #36
    Mar 2009
    2,703
    Hmm, apparently that has not worked though
  7. #37
    30,621
    20
    How so? It's still unchanged and reporting the correct DNS even after reboot.
    Server: 8.8.4.4
    Address: 8.8.4.4
  8. #38
    Mar 2009
    2,703
    How so?
    Well Chromium appears to be ignoring it and using your ISPs DNS servers (presumably from the DHCP on your router). A very off problem to be sure.
  9. #39
    30,621
    20
    Maybe my tinkering fixed it--at least I'm not using systemd for DNS services now. I don't really know what Chromium is doing--I'll just stay away from it for the time being.
  10. #40
    Mar 2011
    Norway/Japan
    971
    Ah, systemd.. that's why I moved to Devuan for my latest computers. Desktop still runs (systemd-infected) Debian.
    I don't have any problems with Chromium and DNS though - I have configured it to always use a proxy. Which is just an SSH tunnel to where the proxy runs. So it's the proxy that does the DNS lookups, not Chromium. Albeit for http only.
