Results 1 to 7 of 7
Thread: Working in IT
    Sep 2008
    Walled Lake, MI
    3,674
    6
    Default Working in IT
    Surely not everyone was Kung-fu fighting
    Dec 2017
    A planet that's evolving And revolving at nine hundred miles an hour
    318
    This is fairly accurate believe it or not.
    I have dyslexia, I have alot of trouble putting my thoughts into words and spelling/grammar is something I struggle with.
    You may need to read my posts twice to understand what I said.
    Jan 2014
    Northfield, MN USA
    149
    Sometimes the green slice is actually bigger...
    Apr 2018
    Los Angeles, CA
    261
    Quote Originally Posted by ScutBoy View Post
    So I had to help someone with their PC yesterday and it was actually a combination of the green and blue.. I came by and it was working fine, but I stuck around long enough (and did a reboot) and it stopped working, turns out it was a Powerline network device that I had to uplug and plug in again (it was red, likely messed up by some power outages the last few days). Showed them what to do next time so hopefully they don't call me again
    -- Brian
    Retro PC's: Apple IIe/II+, Atari 800, Atari 520STFM, Commodore 64, Commodore Amiga 3000, IBM PS/1 2121-B82, TI-99/4A, TRS-80 Model 4 GA, Kaypro 2/84 (Not working )
    Jan 2014
    Western North Carolina, USA
    1,101
    The green slice... aka the Heisenbug. Needs to be bigger.
    Bughlt: Sckmud
    Shut her down Scotty, she's sucking mud again!
    Jan 2014
    Freedom City
    6,380
    2
    I agree.
    This all applies to fixing anything, not just IT. Power-cycling, and repairman simply being present, fix most anything.
    Feb 2011
    NorthWest England (East Pondia)
    1,952
    10
    As Barbara Woodhouse used to say of naughty dogs, the problem usually was the owner not the dog...
    https://en.wikipedia.org/wiki/Barbara_Woodhouse
    .. the same with Computers, often the user gets all hung up and in a panic, and just a calm presence can sort the problem out. Happened to me last week. Problem with a printer. Lots of spurious messages, a calm head and its was all working again, so the green should be much bigger...
    I think there is also a bit missing. That is, if its an intermittent problem, you just break it properly so some one else has to fix it....
    G4UGM
    Looking for Analog Computers, Drum Plotters, and Graphics Terminals
