Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: ISA Multi-IO Board - Preferred Connectors
    Not sure I saw it mentioned, but I'm guessing some people would prefer to have a Joystick port, as most XT games can use them, and not as many people have a soundcard in their XT. I myself would find 9-pin serial and LPT ports useful but a lot of systems with limited ISA slots tend to have at least one of those built in, however I dont think I've EVER seen an XT clone with a built-in game port. Although it may be a bold assumption to think that people that would be interested in such a card would also be interested in gaming....I myself use my XTs for gaming maybe only 10% of the time...
    Just a thought!
    Quote Originally Posted by sergey View Post
    CR2032 batteries are not particularly evil - they don't leak and easily removable and replaceable... And then there is an option to use super caps. Although I think they will not keep RTC running for a very long time
    Used a supercap in my first universal card - kept RTC for a few days (maybe just for one - don’t remember exactly), so moved to 2032.
    P.S. Some offtopic - do you mind making a version (gerber files) of your 16-bit ISA backplane with 24 pins ATX power connector instead of the existing 20 pins one ?
    Quote Originally Posted by Xacalite View Post
    It's 2018, everything is connected to the net, and it's so easy to set the clock via net.
    If it is so easy, please provide/create the needed software for these old 8-bitters.
    With kind regards / met vriendelijke groet, Ruud Baltissen
    www.baltissen.org
    May 2009
    Connecticut
    4,175
    Quote Originally Posted by Ruud View Post
    Some have already done SNTP applications for 8-bit systems. For example, see https://macgui.com/kb/article/764
    For a PC card like this section indicates, there is http://www.brutman.com/mTCP/mTCP_Sntp.html
  5. #15
    Alright, I'll see if I can add an RTC there.
    A RTC would be good, Maybe have a battery header instead of a CR2032 on board so one can use a couple of AA type batteries off board if space is an issue.
