Results 1 to 10 of 13
Thread: Looking for 'Travesty' program
    Default Looking for 'Travesty' program
    Hello,
    I found interesting program A Travesty Generator for Micros
    I typed sourve code, but after compilation on TurboPascal program doesn't work.
    PROGRAM travesty (input, output); {Kenner / O'Rourke, 5/9/84}
    {(*This is based on Brian Hayes's article in Scientific *)
    (*American, November 1983. It scans a text and generates *)
    (*an n-order simulation of its letter combinations. For *)
    (*order n, the relation of output to input is exactly: *)
    (*"Any pattern n characters long in the output *)
    (*has occurred somewhere in the input, *)
    (*and at about the same frequency." *)
    (*Input should be ready on disk. Program asks how many *)
    (*characters of output you want. It next asks for the *)
    (*"Order" i.e. how long a string of characters will be *)
    (*cloned to output when found. You are asked for the *)
    (*name of the input file, and offered a "Verse" option.*)
    (*If you select this, and if the input has a " ! " char- *)
    (*acter at the end of each line, words that end lines in *)
    (*the original will terminate output lines. Otherwise, *)
    (*output lines will average 50 characters in length. *)}
    CONST
    ArraySize= 3000; {maximum number of text chars}
    MaxPat=9; {maximum Pattern length}
    VAR
    BigArray : PACKED ARRAY [1 ..ArraySize] of CHAR;
    FreqArray, StartSkip : ARRAY[' '..'|'] of INTEGER;
    Pattern : PACKED ARRAY [1 ..MaxPat] of CHAR;
    SkipArray : ARRAY [1 ..ArraySize] of INTEGER;
    OutChars : INTEGER; {number of characters to be output}
    PatLength : INTEGER;
    f : TEXT;
     CharCount : INTEGER; {characters so far output}
     Verse, NearEnd : BOOLEAN;
    NewChar : CHAR;
    TotalChars : INTEGER; {total chars input, + wraparound}
    Seed : INTEGER;
    FUNCTION Random (VAR Randlnt : INTEGER) : REAL;
    {41}
    BEGIN
    Random:= Randlnt/ 1009;
    Randlnt:= (31 * Randlnt + 11) MOD 1009;
    END;
    PROCEDURE InParams;
    {* Obtains user's instructions *)}
    VAR
    InFile : STRING [12];
    Response : CHAR;
    BEGIN
    WRITELN ('Enter a Seed (1 .. 1 000) for the randomizer');
    READLN (Seed);
    WRITELN ('Number of characters to be output?');
    READLN (OutChars);
    REPEAT
    WRITELN ('What order? <2 - ', MaxPat,'>');
    READLN (PatLength)
    UNTIL (PatLength IN [2 ..MaxPat]);
    PatLength:= PatLength - 1 ;
    WRITELN ('Name of input file?');
    READLN (InFile);
    ASSIGN (f, InFile);
    RESET (f);
    WRITELN ('Prose or Verse? <p/v>');
    READLN (Response);
    IF (Response='V') OR (Response='v') THEN
    Verse:= true
    ELSE Verse:= false
    END; {Procedure InParams}
    PROCEDURE ClearFreq;
    {* FreqArray is indexed by 93 probable ASCII characters, }
    {* from " " to "! ". Its elements are all set to zero. }
    VAR
    ch : CHAR;
    BEGIN
    FOR ch:= ' ' TO '|' DO
    FreqArray[ch]:= 0
    END; {Procedure ClearFreq}
    PROCEDURE NullArrays;
    {* Fill BigArray and Pattern with nulls *}
    VAR
    j : INTEGER;
    BEGIN
    FOR j:=1 TO ArraySize DO
    BigArray[j]:= CHR(0);
    FOR j:=1 TO MaxPat DO
    Pattern[j]:=CHR(0)
    END; {Procedure NullArrays}
    PROCEDURE FillArray;
    {* Moves textfile from disk into BigArray, cleaning it
    (* up and reducing any run of blanks to one blank.
    (* Then copies to end of array a string of its opening
    (* characters as long as the Pattern, in effect wrapping
    (* the end to the beginning. }
    VAR
    Blank : BOOLEAN;
    ch: CHAR;
    j : INTEGER;
    PROCEDURE Cleanup;
    {(* Clears Carriage Returns, Linefeeds, and Tabs out of
    (* input stream. All are changed to blanks. }
    BEGIN
    IF ((ch = CHR(13)) {CR}
    OR (ch = CHR(10)) {LF}
    OR (ch = CHR(9))) {TAB}
    THEN ch:= ' ' {!!!}
    END;
    BEGIN {Procedure FillArray}
    j:= 1;
    Blank:=false;
    WHILE (NOT EOF(f)) AND (j<=(ArraySize-MaxPat)) DO
    BEGIN {While Not EOF}
    READ (f, ch);
    Cleanup;
    BigArray[j]:=ch; {Place character in BigArray}
    IF ch=' ' THEN Blank:= true; {!!!}
    j:= j + 1;
    WHILE (Blank AND (NOT EOF(f)) AND (j <= (ArraySize - MaxPat))) DO
    {125}
    BEGIN {While Blank}
    READ (f, ch);
    Cleanup;
    IF ch<>' ' THEN {!!!}
    BEGIN {If}
    Blank:=false;
    BigArray[j]:=ch; {To BigArray if not a Blank}
    j:=j + 1
    END {If}
    END {While Blank}
    END; {While Not EOF}
    TotalChars:= j - 1;
    IF BigArray[TotalChars] <>'' THEN
    BEGIN {If no Blank at end of text, append one}
    TotalChars:= TotalChars + 1;
    BigArray[TotalChars]:=' '
    END;
    {Copy front of array to back to simulate wraparound.}
    FOR j:=1 TO PatLength DO
    BigArray[TotalChars + j]:= BigArray[j];
    TotalChars:= TotalChars + PatLength;
    WRITELN('Characters read, plus wraparound = ',TotalChars:4)
    END; {Procedure FillArray}
    PROCEDURE FirstPattern;
    {(* User selects "order" of operation, an integer, n, in the
    (* range 1 .. 9. The input text will henceforth be scanned
    (* in n-sized chunks. The first n-1 characters of the input
    (* file are placed in the "Pattern" Array. The Pattern is
    (* written at the head of output. }
    VAR
    j : INTEGER;
    BEGIN
    FOR j:= 1 TO PatLength DO {Put opening chars into Pattern}
    Pattern[j]:=BigArray[j];
    CharCount:= PatLength;
    NearEnd:= false;
    IF Verse THEN write(' '); {Align first line} {not sure if write}
    WRITE (Pattern[j])
    END; {Procedure FirstPattern}
    PROCEDURE InitSkip;
    {The i-th entry of SkipArray contains the smallest index
    j < i such that BigArrayO] = BigArray[i]. Thus SkipArray
    links together all identical characters in BigArray.
    Starts kip contains the index of the first occurrence of
    each character, These two arrays are used to skip the
    matching routine through the text, stopping only at
    locations whose character matches the first character
    in Pattern. }
    VAR
    ch : CHAR;
    j : INTEGER;
    BEGIN
    FOR ch:=' ' TO '|' DO
    StartSkip[ch]:=TotalChars + 1 ;
    FOR j:=TotalChars DOWNTO 1 DO
    BEGIN
    ch:=BigArray[j];
    SkipArray[j]:=StartSkip[ch];
    StartSkip[ch]:= j
    {188}
    END
    END; {Procedure InitSkip}
    PROCEDURE Match;
    {(* Checks BigArray for strings that match Pattern; for each *)
    (* match found, notes following character and increments its *)
    (* count in FreqArray. Position for first trial comes from *)
    (* StartSkip; thereafter positions are taken from SkipArray. *)
    (* Thus no sequence is checked unless its first character is *)
    (* already known to match first character of Pattern. *)}
    {198}
    VAR
    i : INTEGER; {one location before start of the match in BigArray}
    j : INTEGER; {index into Pattern}
    Found : BOOLEAN; {true if there is a match from i + 1 to i + j - 1 }
    ch1 : CHAR; {the first character in Pattern; used for skipping}
    NxtCh : CHAR;
    BEGIN {Procedure Match}
    ch1:= Pattern[1];
    i:= StartSkip[ch1] - 1; {i is 1 to left of the Match start}
    WHILE (i <=TotalChars-PatLength-1) DO
    BEGIN {While}
    j:= 1;
    Found:= true;
    WHILE (Found AND (j <= PatLength)) DO
    IF BigArray[i + j] <> Pattern[j]
    THEN Found:=false {Go thru Pattern till Match fails}
    ELSE j:=j + 1 ;
    IF Found THEN
    BEGIN {Note next char and increment FreqArray}
    NxtCh:= BigArray[i + PatLength + 1];
    FreqArray[NxtCh]:=FreqArray[NxtCh] + 1
    END;
    i:= SkipArray[i+ 1] - 1 {Skip to next matching position}
    END {While}
    END; {Procedure Match}
    PROCEDURE WriteCharacter;
    {(* The next character is written. It is chosen at Random *)
    (* from characters accumulated in FreqArray during last *)
    (* scan of input. Output lines will average 50 characters *)
    (* in length. If "Verse" option has been selected, a new *)
    (* line will commence after any word that ends with "'"in *)
    (* input file. Thereafter lines will be indented until *)
    (* the 50-character average has been made up. *) }
    VAR
    Counter, Total, Toss : INTEGER;
    ch : CHAR;
    BEGIN
    Total:=0;
    Total:= Total + FreqArray[ch]; {Sum counts in FreqArray}
    Toss:= TRUNC (Total * Random(Seed)) +1;
    Counter:= 31;
    REPEAT
    Counter:=Counter + 1 ; {We begin with ' ' }
    Toss:= Toss-FreqArray[CHR(Counter)]
    until Toss <= 0; {Char chosen by}
    NewChar:= CHR(Counter); {successive subtractions}
    IF NewChar <>'|'THEN
    WRITE (NewChar);
    CharCount:= CharCount + 1;
    IF CharCount MOD 50 = 0 THEN NearEnd:= true;
    IF ((Verse) AND (NewChar = '|')) THEN WRITELN;
    {251} IF ((NearEnd) AND (NewChar = ' ')) THEN
    BEGIN {If NearEnd}
    WRITELN;
     IF Verse THEN WRITE (' ');
     NearEnd:= false
     END {If NearEnd}
    END; {Procedure WriteCharacter}
    PROCEDURE NewPattern;
    {(* This removes the first character of the Pattern and
    (* appends the character just printed. FreqArray is
    (* zeroed in preparation for a new scan. }
    VAR
    j : INTEGER;
    BEGIN
    FOR j:=1 to PatLength - 1 DO
    Pattern[j]:= Pattern[j+ 1]; {Move all chars leftward }
    Pattern[Patlength]:=NewChar; {Append NewChar}
    ClearFreq
    END; {Procedure NewPattern}
    {272}
    BEGIN {Main Program}
    ClearFreq;
    NullArrays;
    InParams;
    FillArray;
    FirstPattern;
    InitSkip;
    REPEAT
    Match;
    WriteCharacter;
    NewPattern
    UNTIL CharCount <= OutChars;
    END. {Main Program}
    I found link in teh internets to travesty.lbr, but file unavailable. Does anyone has listing?
    thank you.
    Cursorily, however, this source code looks rather complete. I don't think a missing library is your problem. What error do you actually get?
    Quote Originally Posted by ClassicHasClass View Post
    *.LBR isn't a linker library, it's an old archive format; presumably the file might've contained a binary built from the source. I couldn't find the file either; the one (relevant) result for it that shows up on Google indicates that "GEnie library 24" would've had it, but none of the CP/M archive sites I know of have that set.
    6,442
    I typed sourve code
    You probably mis-typed the "sourve" code. It compiles and runs, but produces 2 or 3 characters of output. Double-check what you typed with the listing in Byte magazine.
    6,442
    At the very end of the program, you have a reversed comparison. You have <= when it should be >= . Then the program works.
    Also, the output doesn't start to get readable until order 4.
    Mar 2013
    Chaffee, MO
    1,443
    Double check these changes. Search for first and change to second.
    BigArray : PACKED ARRAY[1..ArraySize] of CHAR;
    Pattern : PACKED ARRAY[1..MaxPat] of CHAR;
    SkipArray : ARRAY[1..ArraySize] of INTEGER;
    FUNCTION Random (VAR Randint : INTEGER) : REAL;
    Random:= Randint/ 1009;
    Randint:= (31 * Randint + 11) MOD 1009;
    InFile : STRING[12];
    WRITELN ('Enter a Seed (1 .. 1000) for the randomizer');
    WRITELN ('Enter a Seed (1..1000) for the randomizer');
    UNTIL (PatLength IN [2..MaxPat]);
    PatLength:= PatLength - 1;
    BEGIN {Procedure FillArray};
    StartSkip[ch]:= j ;
    StartSkip[ch]:= j
    Toss:= Toss-FreqArray[CHR(Counter)];
    UNTIL CharCount >= OutChars;
    That should help.
    Larry
    There are no error,but seems program works wrong:
    omg, it works!
    thank you very much!
    Mar 2017
    New Jersey, USA
    560
    In case anyone is interested, a C implementation of this was posted to comp.sources.games on Usenet in December 1989:
    v08i075: travesty - make a travesty of the input, Part01/01
    v08i079: travesty - make a travesty of the input, Patch1
    Jul 2005
    State College, PA
    179
    Neil Rubenking wrote a program called BREKDOWN (Break Down), based on the Travesty program article. It's written for Turbo Pascal and Turbo Database Toolbox:
    http://cd.textfiles.com/bthevhell/300/245/
    I have a version split up into INC files for CP/M 2.2.
