Results 1 to 3 of 3
Thread: Chinon FZ-357 floppy drive jumper settings
    Sep 2016
    Shrewsbury, MA
    712
    Default Chinon FZ-357 floppy drive jumper settings
    I need a 720k only drive, and the only drive I have that may work is a Chinon FZ-357 drive which has a bunch of jumpers in the back and from what I've read seems like it will do the trick. I just need to figure the jumpers out to set it to 720k. I have 4 drive select jumpers that I'm going to leave set to 1, and the other jumpers are labelled MD, MM, RDY, TTL/C-MOS, and DC.
    Jun 2015
    Sioux Falls SD
    221
    Don't change any jumpers. Use 720K disks or cover the HD hole with black electrical tape.
    Sep 2016
    Shrewsbury, MA
    712
    I've been trying to but this computer won't read or write 720k disks in a 1.44mb drive for whatever stupid reason
