Results 1 to 10 of 12
Thread: Opening an original Compaq Portable with no tools
    Default Opening an original Compaq Portable with no tools
    Iíve seen people do all kinds of crazy things to get the outside panels off of these, but Iíve always done it with my bare hands. Iím curious to see if anyone else can do it like this also.
    If not, Iíll post a video of it so you can see how I do it.
    6,540
    Per the top section of page 31 (PDF page 33) of the document at [here] ?
    Yep! Thatís pretty much exactly how I do it.
    Jan 2012
    Connecticut, USA
    2,537
    Yeah I can do it babe handed but the plastic is old and frail and cracks sometimes when I pop palm them
    Sep 2016
    Shrewsbury, MA
    1,195
    I've done it before but the last time a piece snapped off my side panel so I use a screwdriver now
    Iíve had pretty good luck with the plastic on mine so far (aside from the few little breaks that were there when I got the the machine that have nothing to do with it being opened). My Plus doesnít have any cracks and Iíve opened it quite a few times as well.
    3,374
    Ideally one should use something wood or plastic, such as popsicle sticks, to hold the latches open while undoing the others.
    I've opened mine without tools but a previous user already broke one of the places where it pops in, so it is easier.
    May 2016
    Fairfield, Ohio
    427
    I have upon occasion used the wrenches available for replacing a bicycle tire.
    Sep 2016
    Shrewsbury, MA
    1,195
    I've been using the metal slot covers I pulled from a couple cases I junked a while back with a piece of painter's tape on the end. They've been working perfectly for me
    The first time I removed the covers of my portable when I found it in a Salvation Army I did use my bare hands and was surprised by how easy it was. Once I got the thing home I found it much harder and had to use a screwdriver. I am not sure if this is because the covers were slightly loose from being knocked around by the thrift store staff who obviously thought it was just a surprisingly heavy sewing machine or because now that it is my property I am being subconsciously more gentle with it. I will follow the suggestions here and use something plastic or wood to avoid losing any more tabs. one is already missing.
    First post to any forum ever. Woot!
