Results 1 to 2 of 2
Thread: Connecting IBM 3101 Terminal to Mac OS X
    Jun 2018
    Los Angeles, CA
    153
    Default Connecting IBM 3101 Terminal to Mac OS X
    I recently bought an IBM 3101 20 terminal and was hoping I could connect it to one of my computers running OS X and access the unix terminal from it. I have looked around on the internet and found things like screen and getty, but I can't find enough information to get the computer and terminal to communicate. Right now, I'm using a USB to serial adapter with a prolific chipset, as well as a 9 pin to 25 pin serial adapter cable. I'm guessing most of my problems are coming from incorrect set DIP switches. I have no idea what half of them mean, and for the half that I do, I don't know what they should be set to (e.g. Duplex, Parity, Stop Bit, Block/Char, etc...). If anyone has an advice on the software or hardware side that would be greatly appreciated. http://bitsavers.org/pdf/ibm/3101/GA...tion_Apr82.pdf
    Sep 2006
    Silicon Valley
    1,694
    Most of what you find on the net are discussions of using a mac as a terminal emulator out a USB serial port
    What you want is the opposite. This should get you started
    http://www.club.cc.cmu.edu/~mdille3/...l_console.html
