Page 49 of 55 FirstFirst ... 39454647484950515253 ... LastLast
Results 481 to 490 of 543
Thread: I wish to create a new DMA/RAM expansion card for the Tandy 1000 line.
  1. #481
    Feb 2017
    Chilliwack, BC, Canada
    477
    The "key" with ordering from Digi-Key is to keep a shopping cart open for your various projects, and wait until it totals over $100, that way you save by getting free shipping. Unless I need something right away, this is how I order. And when you order cheap components, like 74xx ICs, resistors (10k especially), diodes, etc, order more than you need, so you have spares for trying new ideas on a breadboard and prototyping future designs.
    If someone has just one card other than the RAM card it's probably either the useless modem card or the somewhat less-useless serial card.
    I've got the Tandy DMA/RAM card, my "PLUS" ISA-CF, and an ISA multi-I/O card on a PLUS to ISA ribbon that has to be folded upside down to make the entire stack fit.
    My vintage systems: Tandy 1000 HX, Tandy 1100FD, Tandy 1000 RSX, and some random Pentium in a Hewitt Rand chassis...
    Some people keep a classic car in their garage. Some people keep vintage computers. The latter hobby is cheaper, usually takes less space, and is less likely to lead to a fatal accident.
  2. #482
    May 2011
    Outer Mongolia
    1,586
    Quote Originally Posted by blackepyon View Post
    I guess the way I phrased the sentence was open to interpretation, what I meant was "what Plus card are you likely to find inside of a 256k EX/HX, if it has a card, that you might actually want to keep using?". My EX came with the modem, and I did happen to see an HX with just the serial card on eBay at one point.
    (The modem card in particular doesn't seem to be "rare", I kind of wonder if the 256K machine + modem combo was at some point positioned as a cheap terminal for getting into Compuserve or whatever.)
  3. #483
    Feb 2017
    477
    Besides the RAM card, the RS-232 card would be the most useful, since you could connect an external modem to it, or a mouse.
  4. #484
    I run a mouse plus a WiModem 232 from my serial card and I know a lot of other EX / HX owners would like to do the same.
    My Retro Collection:
    CBM: C64, Amiga 500 x2, 600 & 1200
    Apple's: IIc, Mac SE, LCII, LC630 & Power Mac G3/233 Desktop
    PC's: K6-III+ 500 System + Roland MT-32 & Tandy 1000 EX 640kb, 3.5" FDD, CF-IDE 4GB HDD
    Visit my Tindie store for Tandy 1000 Adapters for EX, HX, SX, SL, TX & TL etc
  5. #485
    Feb 2017
    477
    Quote Originally Posted by dJOS View Post
    I forgot about that. Personally, I'd prefer a hardwired NIC, but the wireless serial "modem" would definitely be useful. You could combine a NIC with a dual RS232 onto one card, maybe with a breakout cable if space is short (right-angle 10-pin .100" header for the second COM port maybe? We've all got those rear-panel-mount serial thingies lying around). Quick check looks like it's possible to fit two DB-9's and an RJ-45 between the screw holes, but you'd need an extension/adapter for the wireless modem.
    I'm thinking you could have a DB-9, an RJ-45, a second RS232 on a 10-pin .100" breakout header for a DB-9/DB-25, and a USB port for 5v external power (or integrate an 8-bit USB controller if you're feeling REALLY ambitious). It would be a really tight squeeze, but it should all fit in the back panel slot.
  6. #486
    This, for sure. You've got to take advantage of the bulk pricing break points. If you spend ~$300 now to stock up on all the basic logic gates, discretes (10k resistor packs and pullups, and bypass and filter caps in particular), breakaway headers, etc, you'll save a pile of money in the long run. They really nickle and dime you to death on small quantities. You pay about 10 cents more per IC buying quantities <10. Resistors are even worse.
    Jameco sells some nice component kits.
    -- Lee
    May Be Interested In Acquiring: Mac IIsi, Quadra 840AV, Commodore PC(286+)/64C/128D, PC-era Tandy stuff, Peculiar Old Serial Terminals.
    Old Computer Fun! (Muh Projects Blahg) | Muh YouTube Channel that goes with it
  7. #487
    So I've spent part of the morning trying to figure out the most efficient way to handle the bus driver(s)' /enable decoding for my multifunction card. My first thought was to use a single '245 and a little glue logic to combine all the /reads and /cardselects to drive the '245, since the RAMs, IDE latches, drive, and 8255 have their own CS signals anyway, so they'll be tri-stated off the B-side of the data bus when they're not being accessed. ... I *think*. Lol.
    This would be easier if I didn't have to deal with memory and IO devices on the same card. The glue logic to sort that out with a single '245 quickly becomes larger than just using more than one '245. So I guess I'll use at least two, one hooked to /ior and one to /memr, handling memory and io devices completely separately. I *think* I can probably use the same '245 for both IDE and the 8255. The 8255 circuit is really simple, and it *looks* like none of that mess of transparent latches nor the drive itself on the IDE side of things will be contaminating the B-side of the data bus while /ide-cs is un-asserted. But I am not 100% confident of that last statement...
    I do have a regular XT-IDE card. Maybe I need to just breadboard out a little test circuit to tell me if anything gets driven on the B-side while /ide-cs is unasserted and clip it on there and see for sure.....
    It may also be possible that the memory doesn't *need* a '245. The Lo-Tech ram implementation uses one, but the Option-ROM section of the XT-IDE does not. And I think Adrian had the same ram chips working well in his circuit without a buffer, once he sorted out the chinajunk. However, my gut feeling is to keep the buffer, and also to redesign the ROM section a little to make use of it.
    How are you guys handling the bus drivers on your multifunction cards?
    -- Lee
  8. #488
    Feb 2017
    477
    Quote Originally Posted by bladamson View Post
    You could probably do one '245 for each, IOR and MEMR. What are you using the 8255 for?
  9. #489
    May 2011
    Outer Mongolia
    1,586
    I just finished soldering and initially smoke testing my new I/O board that has the IDE port and the DUART behind the same buffer and, knock on wood, doesn't seem to be a problem. (I've run the Checkit diagnostic on both serial ports and hard disk, both passed. But I haven't exercised it more than that.) I just combined the respective chip selects with a spare AND gate.
    Likewise my memory board has the RAM and Flash chips sharing a '245, again just combining the chip selects with an AND. So as long as you're fine with two '245s, one each for mem and i/o, a 7408 or similar should do the needful for both sides.
  10. #490
    Quote Originally Posted by Eudimorphodon View Post
    Out of curiosity, what version of Checkit are you using on your EX/HX? The last two versions I have tried do not seem to properly start on mine, but works fine on other XT class computers.
Tags for this Thread
