Results 1 to 2 of 2
Thread: 6516 >>> c64
    Sep 2017
    Principality of Xeon
    1,704
    Default 6516 >>> c64
    I bought a copy of Commodore Format many years ago. The feature article described replacing the 6510 with a 6516 or similar. Does anyone know which issue I'm referring to? I scanned the issues on archive.org and I didn't recognize any.
    Dec 2016
    New Jersey
    196
    Quote Originally Posted by 2icebitn View Post
    The article was originally published in the German magazine 64R and may have been later published in Commodore Format I am not sure. It detailed how to replace the 6510 with a 65C02 (and the design is very easily adapted to the 65c816).
    Neither the 6502 nor the 65816 have the I/O ports and logic that were added to the 6510 by Commodore, so you have to build a daughter board with a 6522 VIA or similar to add the ports externally.
    The basic concept is explained here:
    http://www.baltissen.org/newhtm/10to816.htm
