Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: FDISK "Divide Overflow" on 256MB CF Card
  1. #21
    Do you have another PC with a serial port as well as a null modem cable? You could even make a null modem cable; it's pretty easy.
    You could use something like fastlynx to transfer over the xtidecfg utility over serial. Fastlynx can upload itself over the serial port to your machine; so you don't need to write it to your floppy disk.
  2. #22
    Dec 2018
    Western New England
    26
    So, my coworker and I were able to fix the BIOS and the card. My soldering was partly to blame, my solder itself was also partly to blame. We reflashed the XT-IDE BIOS and I'll now be keeping that stuff safely tucked away on a disk.
    Because I was able to read and write to the CF card (but still not boot), I copied MS-DOS 5.00 install disk images to it and then wrote them to 5 360k floppies. I then made an MBR on the CF card with FDISK /MBR, deleted the drive's partitions with FDISK, made a new 256 MB partition on the drive, set it to "Active", and reformatted it with FORMAT. From there, I was able to install DOS 5 from disk and the CF card boots the system as a hard drive.
    Thanks to everybody here for all of your help on this problem!
    Sent from the mobile client - Forum Talker
