Results 1 to 3 of 3
Thread: Looking for Commodore Power Supply
    Jan 2013
    Pittsburgh, PA
    1,222
    Default Looking for Commodore Power Supply
    Looking for a C64 / VIC-20 Breadbin power supply......untested / not working is fine as I plan on only using the cable and DIN connector from it to make a new one....I know I can get a DIN cable but I suck at soldering small wires onto the DIN Pins, so using the cable and then soldering new wires to those wires I can actually do!!!
    "In Life, The Days Are Long But The Years Are Short..."
    Dec 2016
    New Jersey
    196
    Quote Originally Posted by Smack2k View Post
    I have a spare beige c64C power supply that is beat up but has the parts you need (it actually works).
    Fwiw, I have the DIN connector on-hand. If you can provide a suitable length of cable, I'd be happy to solder it on for you. No charge, just cover the shipping.
