Results 1 to 3 of 3
Thread: Correct 7 Pin DIN connector for power of C64
    Jan 2013
    Pittsburgh, PA
    1,222
    Default Correct 7 Pin DIN connector for power of C64
    Can someone recommend me a good, correct 7 Pin DIN connector that can be used to connect to the power in of the Breadbin C64 / VIC20? Building a power supply for a couple of machines I received for free to test them and use / clean/ repair, as they came with no power supplies...
    Looking for a connector with solder cups so I can easily attach the wires to it using the cups...
    THANKS!!
    "In Life, The Days Are Long But The Years Are Short..."
    Oct 2017
    SE Michigan, USA
    437
    Found some on eBay: https://www.ebay.com/itm/283241589031?nordt=true
    I bought a few of the 8-pin 262 degree DIN connectors for making an A/V cable for my C64, which works very well (added noise reduction and a 300Ohm resistor for the Chroma signal on the S-Video cable).
    Current retro systems:
    2x Commodore 64 Breadbin 250407 Rev. B and C
    Packard Bell Pack-Mate 28 Plus, aka, the Ultimate Sound Card machine
    iMac G3/600 Graphite, Mac OS X 10.4.11 Tiger, Lubuntu 16.04.3 LTS
    iMac G4/800 Lampshade, Mac OS X 10.4.11 Tiger
    YouTube channel: https://www.youtube.com/c/RetroPCUser
    Jan 2012
    Raleigh, NC, USA
    478
    I used REAN NYS323 connectors for the SaV64. Very high quality. You should heat shrink the individual wires because of the metal DIN sleeve.
    I'd love to see your final project!
    Heather
