Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: History behind the disk images of AT&T UNIX System V Release 4 Version 2.1 for 386?
  1. #21
    Sep 2006
    Silicon Valley
    1,817
    Quote Originally Posted by alecv View Post
    I
    Was the AT&T 6386 compatible with conventional PC or not ?
    Yes, it will run stock IBM DOS 4.0. The machine was built by Olivetti
    It uses a western digital ESDI disk controller and a Paradise VGA
    I think they modified the DOS for the diagnostics. The images on the NCR
    website weren't bootable so I copied them to a DOS 4.0 system that I had
    but they didn't seem to work quite right. I ended up using the Western Digital
    wdfmt formatting program to initialize the disk. The BIOS setup program from the
    NCR disk did set up the CMOS. I had to do some digging around to find the
    drive table. It is in the Olivetti PC guide. IBMIO.COM on the diags has an ATT
    copyright
    AT&T Information Systems
    June 1986
    Authors
    Joann F. Doyle - AT&T IS Freehold, N.J.
    James R. Rankin - AT&T IS Freehold, N.J.
  2. #22
    Feb 2010
    Russia, St.Petersburg
    192
    JFYI: There was yet another "branded" SYSVR3 from the Wyse, but earlier version 3.2.1A
    It was virtualized recently.
    https://virtuallyfun.com/wordpress/2...again-sort-of/
    https://virtuallyfun.com/wordpress/2...-challenge-ii/
    https://virtuallyfun.com/wordpress/2...x-virtualized/
    It has a full SGS package (on the tape image, record 00003)
    C Software Development System 4.1.5 3/31/88
    P.S.
    There was also yet another "branded" SYSVR4 (4.0_2.2) from DELL
    https://virtuallyfun.com/wordpress/2...x-lives-again/
    https://technologists.com/notes/2008...-of-dell-unix/
