Results 1 to 8 of 8
Thread: IBM Fixed Disk and Diskette Drive Adapter For 5170
    Default IBM Fixed Disk and Diskette Drive Adapter For 5170
    I must have a bad fixed disk card in one of my ATs. It occasionally throws a 601 error on post. Also it always throws a “ disk unusable” Error when trying to format a diskette. Reading is also flakey. Not sure what the issue is.
    I borrowed a card from my other system and it seemed to work normally.
    I suppose I need a replacement card.
    I have a Major in Post-Apocalyptic Economics.
    Wanted: Any PC-Compatible Reciprocation Dingle Arm
    May 2006
    Melbourne, Australia
    6,019
    Quote Originally Posted by offensive_Jerk View Post
    Have you tried cleaning the edge connectors, if for no better reason than it is easy to do ?
    No, I should try that though.
    I did replace the capacitors just because I had a different one that had a shorted capacitor. Didn't help.
    Jan 2013
    Marietta, GA
    2,895
    You might check the power supply. I have seen an instance recently where it seemed noisy/weak power may have been responsible for intermittent floppy issues. Similarly, you might test the card in a minimal configuration or in another machine.
    I had the similar issue. Abort, Ignore, Retry on disk A; hang on disk B. Two things may have been at play. The Terminating resistor chip which should have only been installed on Drive A and swapping molex connectors, which could have related to the power supply like SomeGuy mentioned or dirty terminals.
    Cleaned the contacts, no luck. Invalid media or track 0 bad message on both a and b drives.
    Swapped a different card in from a 5170 that just blew the psu and both drives formatted fine.
    Strange...
    Mar 2009
    Pleasant Hill, CA USA
    2,673
    Is that an MFM controller? If so I can dig through my small collection of the things and send you one or two that may or may not work for the cost of shipping if it helps.
    29,553
    20
    I've got several 16-bit RLL floppy+HD controllers that are collecting dust here. Good (WD1006V-SR2) for their day, but hopelessly obsolete today. I drop you one for the cost of shipping.
