Results 11 to 20 of 25
Thread: PC 5170 need help with PAL16L8 and 28S42
  1. Default
    U87 is done. Unfortunately, Minilog can't handle more than 2000 input terms, so just a raw file for now:
    U87.zip
    Does anyone know where to get some software that can minimize this file ?
    Apr 2019
    Texas USA
    29
    Curious, I've been wanting to program these also and just wondering if I would just load these files up in my programmer and burn it or is there more to it?
    You need to look for 3state controls as well as high and low on the pals.
    Mar 2011
    Atlanta, GA, USA
    1,548
    Quote Originally Posted by newold86 View Post
    Sigh...
    LogicFriday is a great tool for this. But it seems the author's web-site is expired. Still available on CNET.downloads.
    Minimized:
    ENDCYCn = RES0WS FSYS16' Q4' AIOW' IORn  + RES0WS FSYS16' Q4' IOCS16  + RES0WS Q4' Q1' ;
    DMAAENn = AEN2n AEN1n ;
    GATE245 = AEN2n XA0'  + AEN2n' AEN1n  + FSYS16' AEN1n'  + FSYS16 AEN1n AIOW' IORn  + FSYS16 AEN1n IOCS16'  + AEN1n XBHE;
    DIR245 = AEN1n AIOW'  + AEN2n' AEN1n  + AEN1n XBHE;
    DATACONV = FSYS16 AIOW' IORn  + FSYS16 IOCS16'  + Q1'  + AEN1n'  + AEN2n'  + XA0  + XBHE;
    Quote Originally Posted by Sabertooth View Post
    No, not in this form, meaning the zip file, not eeguru's source level code. It it possible to do a EPROM or FLASH but you have to make sure the circuit it controls is protected from glitches. A PAL has logic in a particular sequence. A ROM may have any combination of address that are changing as glitches on the output.
    Mar 2011
    Atlanta, GA, USA
    1,548
    I also ran U130 through LF and got the same minimizations.
    IRQ13 = ERRORn' ;
    BUSY286n = 0;
    NPCSn = XA3' + INTAn'  + CS287n  + SMIO ;
    RESET287 = INTAn CS287n' SMIO' XIOWn' XA0 XA3' + RESET ;
    Simplest next step is rewrite the minimization syntax in CUPL and create a JEDEC file for ATF16V8 programming. Those are still available new from most online parts distributors. If you post the pinouts, I can do that if you like.
    Many PROM programmers with burn ATF16V8s. If you don't have one, I can burn and send you a few.
    Apr 2019
    Texas USA
    29
    Well, in that case hopefully the ones I pulled off the board are still good. It just would have been nice to have a backup ready just in case. Thanks
    33,656
    Amazing that I did a 14-part blog on this in 2011 and nobody seems to have noticed.
    And an excellent blog it is Unfortunately not easily found with the ton of garbage that's in the blog section, I was looking for that a while back and got miffed at all the crap in there, Then it dawned on me to find one of your post's and click on the blog entries:
    Nice but what about 3state outputs?
