Results 1 to 6 of 6
Thread: Search doesn't work
    Default Search doesn't work
    If I search for all posts by myself, it returns nothing.
    Mar 2009
    Pleasant Hill, CA USA
    2,721
    Use google, just add "site:http://www.vcfed.org/forum" to the search term (no quotes of course).
    30,979
    VCF search function hasn't worked right in a long time. Google site search gets what you're after, as lutiana says.
    You can also just use:
    site:www.vcfed.org
    which works exactly the same.
    Actually, I prefer using a bookmarklet as it's easier than typing all that. It supplies everything but the search term itself which it prompts you for when you click on it:
    javascript:function f(){var q=prompt('Search for');if(q!=null){location.href='http://google.com/search?q=site:'+location.host+'+'+encodeURICompone nt(q);}}f();
    FWIW, this bookmarklet will work for any site you're currently on (IOW, it's generic) as there is no location hard coded into it.
    Thanks for answering. I'll try that next time.
    It works now.
