Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Atari 800 (not XL) ROM slot problem
    Jan 2011
    Vancouver, BC
    4,243
    Yeah I hate cheating... but in this case for $14 if I can just eliminate the problem then why not. It's not like the board in mine is rare or early.. says Rev 6.
    I am curious about the serial sticker though.. the handwritten part isnt unusual.. but the numbers usually start with AW and have a machine printed component above.
    Are you using rubbing alcohol or Isopropyl (IPA)? Lots of water and perhaps other stuff in rubbing alcohol which would lengthen drying time. I'd try using something like CRC electronic cleaner spray.
