Results 1 to 10 of 30
Thread: IBM 5150(A) motherboard in trouble
    Default IBM 5150(A) motherboard in trouble
    Hi, i have serious problem with early 5150 (first BIOS) motherboard. It appears to be "dead". Let me list some main facts.
    - no beep codes
    - no "speaker crack" on power on
    - with Landmark Supersoft ROM - no video, no beeps
    - motherboard is not shorted, voltages are good
    - first 16k of RAM - TESTED.
    - CPU - TESTED
    - ROM - TESTED
    - BASIC - TESTED
    - 8255 IC - TESTED
    - RN1 - RN3 resistor blocks - TESTED
    Any other ideas?
    IBM PC 5150(A): IBM PC 5150(B): IBM PC 5160 (64-256k): IBM PC 5160 (256-640k): IBM PC 5170 (099): IBM PC 5170 (319/339): IBM PC 5140: IBM PC 5162: IBM PC 5155:
    WANTED! : IBM 5161 Expansion unit, IBM 5175 monitor, IBM 5145 monitor, IBM EGA Graphics Memory Expansion Card, IBM PC screws,
    My IBM PC hardware collection
    Have you run modem7's Minimum Diagnostic Configuration?
    yes indeed
    What were the results?
    dead motherboard?
    Quote Originally Posted by romanon View Post
    dead motherboard?
    C'mon, that is not one of the results!
    Be specific.
    results are here
    - no beep codes
    - first 16k of RAM - TESTED. (passed on other motherboard)
    - CPU - TESTED (passed on other motherboard)
    - ROM - TESTED (passed on other motherboard)
    - BASIC - TESTED (passed on other motherboard)
    - 8255 IC - TESTED (passed on other motherboard)
    - RN1 - RN3 resistor blocks - TESTED (passed)
    motherboard is still without any traces of life
    29,949
    Time, I think, to get out the scope and check some signals, no?
    probably yes, but this is little bit above my skills. Motherboard is now in skilled hands. I have friend with scope. Some advice, which IC measure first?
    29,949
    Check to see that the 8088 is getting a proper clock signal and the address lines are twitching to start with.
