Hi guys,
There is now a special 11/40 adapter board for the BlinkenBone system.
With that you can plug a physical 11/40 panel to the extended SimH running on a BeagleBone.
Surprisingly there was some demand for the 11/70 panel adapter, so the adding the '40 panel may be worth mentioning.
There is no own '40 documentation, see again the 11/70:
http://www.retrocmp.com/projects/bli...d-play-adapter
If you want it: I made the '40 10 cheaper then the '70.
Entry to far-too-many web pages here: http://retrocmp.com/projects/blinkenbone
All in all there are now at least 6 different (but compatible) ways to get a blinking PDP-11's with SimH.
- Connect a real 11/40 or 11/70 panel.
http://retrocmp.com/projects/blinken...p-11-70-panels
- Run the virtual Java panels for 11/20, 11/40 or 11/70, also with play isntruction for the physical ones:
http://retrocmp.com/projects/blinken...dp-11-20-panel
http://retrocmp.com/projects/blinken...apertape-basic
http://retrocmp.com/projects/blinken...h-the-pdp11-40
http://retrocmp.com/projects/blinken...pdp11-40-panel
http://retrocmp.com/projects/blinken...elsim-pdp11-70
Download & run from github https://github.com/j-hoppe/BlinkenBone/releases
- get Oscars Vermeulens PiDP11
http://obsolescence.wixsite.com/obsolescence/pidp-11
Happy blinking!
Joerg
